5th gen Accord noises :-\
Old Aug 17, 2004 | 02:41 PM
CiBBeasT's Avatar
Default 5th gen Accord noises :-\
I cant figure this problem that i have out and i figured you guys might be able to help me.
I have a 96 accord. When I'm doing cruising speeds on the highway my car starts to make a droning noise. It sounds like its coming from under the hood or right under my feet. i cant tell.
It only makes this noise at 2500rpms. I will be doing around 60-65 and it will drone at 2500. If i press the gas more it stops then starts again once the car revs down to that 2500 mark. If i take my foot completely off the gas the rpms will hang at 2500 until it downshifts and the droning will lower with the rpms until im at about 2200 where it sounds normal again.
I know its not the brakes because i got new rotors and drums not too long ago.
Any ideas would be greatly appreciated
Old Aug 17, 2004 | 03:11 PM
SuperSlow's Avatar
Default Re: 5th gen Accord noises :-\ (CiBBeasT)
Only in 5th gear?
If not,
Probably just your exhaust.
Old Aug 17, 2004 | 03:35 PM
motormanSR's Avatar
Default Re: 5th gen Accord noises :-\ (SuperSlow)
sounds like a problem in your exhaust to me....that happened to me after my stock exhaust system blew and i bought an autozone mid-pipe (with resonator)...the worst thing have ever put on my car!!!!!!!!
this angered the gods!!!!
Old Aug 19, 2004 | 04:01 PM
RUBZERK's Avatar
Default Re: 5th gen Accord noises :-\ (motormanSR)
it may be the heat shield that is welded to the mid-pipe. took mine off my 96 & the sound is gone. to much vibration
meangreenEG
Jul 7, 2009 12:25 PM
skim19104
Aug 1, 2004 03:54 PM
RUBZERK
Nov 4, 2003 10:24 AM
DeLiRiOu5
Jul 12, 2003 09:12 PM
fe519
Dec 26, 2001 12:11 PM
