2nd oil change on b16 still smells like gas.
i changed the oil again on my b16. i only ran it for 2 weeks this time (less than 500 miles), it was dark brown and smelled like gas. i bought the motor from hmotorsonline, will they do anything for me? what should i do?
you might want to check you fuel pressure first off... and check your compression as well... your fuel pressure could be to high and your dumping to much fuel and its washing past the rings.
exactly could be a bad FPR, or stuck fuel injector.
if not check ignition, ECU, or a bad signal to teh map sensor from a vafc or fuel controller
95 civic b16
Sep 25, 2010 12:09 PM
