99Si B16A2 into 96 coupe, need help
Old Aug 17, 2004 | 12:26 PM
p_legit's Avatar
Default 99Si B16A2 into 96 coupe, need help
My boy and I are doing our first swap on my 96 civic coupe (euro spec, 1.6 sohc, non-vtec, ex luxuries) on Friday. I have all the mounts, axles and drive shaft, tranny, wiring harness and ecu.
how hard is it to run the wiring harness? i am sure my boy and i can do the swap, he is a DSM guy and is a knowledgeable mechanic, but the wiring worries him?
will my stock exhaust work for the mean time? will the CAI that came with the motor line up in my car? ( i am pretty sure it will, they were both in coupes)
Old Aug 17, 2004 | 12:34 PM
DxVteC's Avatar
Default Re: 99Si B16A2 into 96 coupe, need help (p_legit)
Well DSM is different from JDM. It wouldnt be too hard since you've got the B16a2 motor the only prob you gonna run into is the wiring. If i were you i would buy a conversion harness that will allow you to run the obd2b ecu in a obd2a ecu setup. You shouldnt run into that much problems because your swaping obd2 into obd2.
Old Aug 17, 2004 | 10:04 PM
p_legit's Avatar
ttt
EP3phantom
Aug 18, 2011 08:50 AM
Civiclx
Aug 16, 2003 07:03 PM
pbomers
Apr 16, 2003 04:48 PM
