Drain and fill : Transmission fluid
Old Aug 17, 2004 | 09:38 AM
accord115's Avatar
Default Drain and fill : Transmission fluid
I've read a few posts and many of you guys say to drain 2.5 quarts/fill 2.5 and then repeat the process. So in total, I'll use 5 quarts. When I went to honda to buy the fluid, the guy said just drain and fill 3 quarts ONCE, which will leave some old fluid mixed in there. Which option should I do? 98accrd. thanx
Old Aug 17, 2004 | 09:45 AM
idragen's Avatar
Default Re: Drain and fill : Transmission fluid (accord115)
first, do not get mad at the service dept...second i belevie you should listen to the honda technicians...third, say wassup to jerome for me
Old Aug 17, 2004 | 10:29 AM
accord115's Avatar
Default Re: Drain and fill : Transmission fluid (idragen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idragen &raquo;</TD></TR><TR><TD CLASS="quote">first, do not get mad at the service dept...second i belevie you should listen to the honda technicians...third, say wassup to jerome for me </TD></TR></TABLE>
WHAT?!!?
WHAT!!??
Old Aug 17, 2004 | 11:47 AM
TOAB's Avatar
pop the bolts out, let it drain, put the bottom plug back in, start filling, let the excess run out the top, put the top one back in...
if you want to get all the old crap out, i think you need a flush??
Old Aug 18, 2004 | 08:24 PM
Grumpy611's Avatar
The capacity for a tranny drain/refill is 2.6 Qts. as per the Helm's manual for a '98 Accord.
Best bet is to drain/refill two times. Make sure car is operating at normal temp.
You'll know this when the fan kicks in.
You're also going to need to buy 6 Qts.
Old Aug 19, 2004 | 03:24 AM
James's Avatar
Default Re: Drain and fill : Transmission fluid (Grumpy611)
I think 3 qt would suffice - and not to repeat it twice. if you want to do it right, you also should do the engine oil change twice.. I do not think it makes sense or is necessary. maybe some people could use some life here. most important thing is to ensure you have changed the transmision oil on schedule and let alone change it twice.
there are zillions of things you could go overboard with cars.
I have changed my trans. oil say 3 times with my accord and it has 180 k miles and it going strong. No, I did not do the oil change twice.
Old Aug 19, 2004 | 06:42 AM
JimBlake's Avatar
Default Re: Drain and fill : Transmission fluid (James)
I've always heard that if the fluid looks & smells good, just drain & fill once as preventative maintenance.
If the fluid smells burnt or looks brown, then drain & fill 3 or 4 times so you remove as much of the bad fluid as you can.
bigburly
Sep 26, 2018 08:11 PM
singher01
Jul 25, 2008 10:19 AM
rayccfhk
Mar 3, 2008 07:32 PM
dc5 kid
12
Nov 2, 2007 12:17 PM
IntegR
Dec 23, 2006 09:11 AM
