FS: JDM SIR-G pistons+crank, antenna
Old Aug 17, 2004 | 09:05 AM
extreme95gsr's Avatar
Default FS: JDM SIR-G pistons+crank, antenna
Up for sale are pistons and crank out of my jdm b18c motor. The pistons have only been ran for about 35k and are still in good condition. In a stock gsr motor they will yield a 10.6:1 static CR. In an ls motor it will bump it up to around 10.2:1. These pistons are what gives the b18c its 6 more hp over the usdm b18c1.
The crank is used for the same amount of milage and is in good condition except for one of the journals has some bearing wear. All it needs is to be ground down a little it is perfectly fine.
Stock antenna assembly (no mast)
Modified by extreme95gsr at 4:15 AM 8/19/2004
Old Aug 17, 2004 | 02:13 PM
Default Re: FS: JDM SIR-G pistons+crank, antenna (extreme95gsr)
bump
Old Aug 18, 2004 | 02:47 PM
Old Aug 18, 2004 | 07:15 PM
new pics up. pistons have been cleaned and look like new
blazinearth
May 20, 2009 08:46 AM
RSGGSR
May 14, 2009 11:41 AM
1990_integra_DA9
Dec 2, 2007 10:08 AM
likaciv
Jan 18, 2004 11:39 AM
