which size cat?
Old Aug 17, 2004 | 08:47 AM
1998teg's Avatar
Default which size cat?
im ordering a cat for my integra ls and it will be hooked up to a 2 inch header and a 60mm exhaust (2.333in). carsound doesnt make a direct fit for my car so i have to get flanges welded on. other people on hondatech told me to go to kteller8. I did that and now i need to figure out which diameter cat i should get. should i get the 2 inch or the 2.25.
Old Aug 17, 2004 | 09:44 AM
dFreezy's Avatar
Default Re: which size cat? (1998teg)
stock is 2.25 piping
Old Aug 17, 2004 | 12:14 PM
Pawwalski's Avatar
Default Re: which size cat? (bl@sterVT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bl@sterVT &raquo;</TD></TR><TR><TD CLASS="quote">stock is 2.25 piping</TD></TR></TABLE>
Are you sure? I thought stock was around 2" OD.
Old Aug 17, 2004 | 02:09 PM
dFreezy's Avatar
Default Re: which size cat? (Pawwalski)
you're right stock piping is 2". what i meant to say was that with that setup, he will need a 2.25" flange on one end of the cat to match up to the exhaust
Old Aug 18, 2004 | 08:38 AM
1998teg's Avatar
the 2.25 will bolt up to the 60mm exhaust even though it isnt exactly the same?
Old Aug 18, 2004 | 08:53 AM
purplegsr's Avatar
yes, the 2.25" flange will bolt to a 60mm (2.36") flange. There will be a bottleneck, but most people live with it.
Old Aug 18, 2004 | 10:13 AM
slowacura's Avatar
Default Re: which size cat? (purplegsr)
yep i have the same setup and went w/ a 2.25":
Old Aug 20, 2004 | 09:06 AM
1998teg's Avatar
Default Re: which size cat? (inteGSR)
where did you get your cat. im about to get mine from kteller for about 160. let me know if you know where to get one cheaper.
LH-93
Oct 19, 2008 10:33 AM
climb_on
Jul 20, 2007 07:18 PM
one slow coupe
Jan 18, 2005 10:29 AM
TypeR864
Jan 7, 2005 03:22 PM
silentkill03
Nov 5, 2004 02:09 AM
