how long can a stock lude take a 75 shot of nos ?
Old Aug 17, 2004 | 08:19 AM
BLACK_DEL_SOL's Avatar
Default how long can a stock lude take a 75 shot of nos ?
ive been running nos on my stock lude for about 3 weeks (only use it on weekends) im using wet nos with jets setup for a 75 shot .when i use it i only hit the button for a few seconds nothing too crazy and i use it wot and no lower than 2nd gear at least 3500 rmps. how long before i have engine trouble ? my engine has 160k miles on it but still kicks major ***
Old Aug 17, 2004 | 08:20 AM
PrecisionH23a's Avatar
Default Re: how long can a stock lude take a 75 shot of nos ? (BLACK_DEL_SOL)
Do compression tests every week and find out.
There is no definite answer as to how long the motor will last.
Old Aug 17, 2004 | 08:22 AM
Boost Addict's Avatar
I ran a 75 shot on my lude for over a year, no problems.
Old Aug 17, 2004 | 08:24 AM
Default Re: how long can a stock lude take a 75 shot of nos ? (xPRELUDEx)
what should some decent #s be for a h23 lude
Old Aug 17, 2004 | 08:40 AM
H23 Power's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLACK_DEL_SOL &raquo;</TD></TR><TR><TD CLASS="quote">what should some decent #s be for a h23 lude</TD></TR></TABLE>
what kind of numbers???
Old Aug 17, 2004 | 08:41 AM
Default Re: how long can a stock lude take a 75 shot of nos ? (H23 Power)
^^^^ hahahahha
Old Aug 17, 2004 | 08:42 AM
SKDRCR's Avatar
An h23 lude with a 75 shot should be in the low 14 easy.
EDIT: if you're talking about compression #'s for an h23
it should be around 165-175 across
just make sure the numbers aren't to inconsistant
between cylinders.
Modified by SKDRCR at 11:55 AM 8/17/2004
Old Aug 17, 2004 | 08:43 AM
98TypeSH's Avatar
Default Re: how long can a stock lude take a 75 shot of nos ? (SKDRCR)
i think he was asking compression numbers, but i could be wrong. put a 75 shot in your h23 and tell us you best time.
Old Aug 17, 2004 | 08:46 AM
Default Re: how long can a stock lude take a 75 shot of nos ? (98TypeSH)
i meant compression #s and i will post my track #s once i go
Old Aug 17, 2004 | 08:56 AM
SKDRCR's Avatar
post edited
Old Aug 17, 2004 | 09:53 AM
LudeyKrus's Avatar
It will last as long as you are responsible with its use and as long as you take proper care of your motor.
Old Aug 17, 2004 | 11:21 AM
jdmcivicferio's Avatar
Default Re: (LudeyKrus)
I ran a 55 shot on a single cam for 2 years, then sold it to someone who put a 75 shot it lasted another 2 years, then the motor started to lose a little compression, by the way this was on a 1.5L 102hp honda motor, ALL STOCK. The poor motor must have seen at least 100 bottles, either way as long as you have your timing good and colder plug, with proper octane it will be fine.
Old Aug 17, 2004 | 12:24 PM
Default Re: (jdmcivicferio)
forgot to say im running cheap gas with stock plugs, ive look for colder plugs but the dumbass at pepboys and auto parts store dont know what im talking about can you guys give me some part numbers ?
Old Aug 17, 2004 | 02:15 PM
SKDRCR's Avatar
Default Re: (BLACK_DEL_SOL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLACK_DEL_SOL &raquo;</TD></TR><TR><TD CLASS="quote">forgot to say im running cheap gas with stock plugs, ive look for colder plugs but the dumbass at pepboys and auto parts store dont know what im talking about can you guys give me some part numbers ?</TD></TR></TABLE>
I believe they ngk Bkr7e's
someone correct me if i'm wrong.
Old Aug 17, 2004 | 02:27 PM
ZEX sells plugs that are made to be used with forced induction
Old Aug 17, 2004 | 02:42 PM
LudaMan's Avatar
Look what I can do!
Default Re: (xPRELUDEx)
ZEX and NGK are the ones i've heard of. They seem to work pretty well with my friends here
Old Aug 17, 2004 | 04:44 PM
Kal's Avatar
Kal
Default Re: (LudaMan)
the NGK are better.
ArmaanOG
Mar 11, 2009 10:22 AM
alex@killian.com
Jul 13, 2007 06:19 AM
D.A.luder
Feb 17, 2005 04:07 PM
92blackprelude
Sep 9, 2004 08:05 AM
