Brake/Axel/16 Swap question...?
Ok, so my 91 wagon will get the B16, and for it I know the axels will need to be swapped to handle the new transmission. Also in my car I'm wanting to step up to the big brake kit (probably brembo or AEM) but they only fit 92 and up. For the swap, am I going to be doing the 92-95 axels? Or will I still be running the 91 axels? Or does it really even matter? Any help would rock my world...
Depends on the intermediate shaft you use. If it is a 90-93 integra use the 90-93 integra axles. If it is a Y1 intermediate shaft you need to buy or make custom length axles. You can also use a newer b series intermediate shaft and the corresponding axles as well as long as they are non abs. For big brakes check out
http://www.fastbrakes.com
ricardo13d
10
Oct 6, 2009 01:37 AM
philkehn
18
May 28, 2007 08:24 AM
freak86
Oct 20, 2006 07:51 PM
