cp pistons rings with je pistons
Old Aug 17, 2004 | 07:23 AM
ssr_h22's Avatar
Default cp pistons rings with je pistons
i ordered je 9to1 stock bore pistons.
they sent me cp piston rings with it. i just want to know if it will work.
cp rings with je pistons
Old Aug 17, 2004 | 08:17 AM
beepy's Avatar
Default Re: cp pistons rings with je pistons (ssr_h22)
Rings are rings. Most likely they weren't even made by cp.
Old Aug 18, 2004 | 07:56 AM
ms1motorsports's Avatar
Just make sure to properly gap the rings and check ring to ringland clearance.
Old Aug 18, 2004 | 08:05 AM
earl's Avatar
What makes you think they are CP rings? CP does not make rings and if they did, CP is probably the last place JE would buy them from.
Old Aug 18, 2004 | 06:29 PM
ssr_h22's Avatar
i got rings and the box says cp. so i am assuming cp made them.
i need my question answered.
Old Sep 6, 2004 | 08:32 AM
numba1's Avatar
Default Re: (ssr_h22)
Yes they will work,just file fit them and check for correct clearances, and you will be o.k.
Old Sep 6, 2004 | 09:21 AM
pip9's Avatar
Default Re: (numba1)
i used je rings with cp pistons so u shouldn't have a problem the other way around. rings are rings
ziurek filmus
Apr 16, 2017 10:17 PM
crex23
Feb 2, 2006 05:41 PM
all motor b20b
Jan 30, 2005 04:01 PM
swlabhot
May 13, 2004 01:38 PM
nicklk
Jan 27, 2004 12:58 PM
