Replacing OEM With Brembo rotors question
Old Aug 17, 2004 | 06:39 AM
TheNasty0ne's Avatar
Default Replacing OEM With Brembo rotors question
98EK Hatch
If you replace the front rotors for Brembo slotted and drilled is it a direct replacement or do you need to replace the caliper and so fourth?
Old Aug 17, 2004 | 06:43 AM
kelvar13's Avatar
From: centreville, Virginia, United States of America
Default Re: Replacing OEM With Brembo rotors question (IncrediVTec)
as long as the rotors are the right size you should only need to take off the stock rotor and replace it with the drilled/slotted brembo rotor
Sijray21's Avatar
as long as it's a stock size no
big brake kits obviously require modifications
just curious, why are you getting slotted or drilled? show?
Old Aug 17, 2004 | 06:44 AM
PLAN:B's Avatar
It is a direct fit if they are the oem size. If it is a big brake kit you need the caliper bracket.
Old Aug 17, 2004 | 06:51 AM
Default Re: Replacing OEM With Brembo rotors question (Sijray21)
for better braking....
Old Aug 17, 2004 | 06:58 AM
Solracer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">just curious, why are you getting slotted or drilled? show</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IncrediVTec &raquo;</TD></TR><TR><TD CLASS="quote">for better braking....</TD></TR></TABLE>
Right.........
Old Aug 17, 2004 | 06:59 AM
Default Re: Replacing OEM With Brembo rotors question (Solracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Solracer &raquo;</TD></TR><TR><TD CLASS="quote">
Right.........
Ok.
Old Aug 17, 2004 | 07:03 AM
Solracer's Avatar
Read and Learn..
http://www.teamscr.com/rotors.htm
And if your really board http://corner-carvers.com/altimathread.php.html
Short Answer, save your money by Brembo Vented Blanks, not cross drilled and slotted.
Old Aug 17, 2004 | 07:07 AM
Alright thanks... just didnt know all the facts...next time dont make it seem like your a blah...
Old Aug 17, 2004 | 07:08 AM
Sijray21's Avatar
this has been covered alot, but i'm just trying to save you some headache's, money, and future issues since they don't last as long and they're a lot more expensive (not to mention the prone to crack/break)
better braking = better pads and tires
I'm not condoning drilled or slotted rotors, but the main reason people get them is for show. (nothing wrong with that)
but if you honestly want better braking stick with blanks, they're cheaper, they won't eat ur pads, much much less prone to crack/break....it's a win/win/win/win situation unless you're going for the $*$BLING$*$ factor
Old Aug 17, 2004 | 07:12 AM
Kalokohan's Avatar
New User
Don't forget the impact screwdriver, another headache that can be avoided.
Old Aug 17, 2004 | 07:16 AM
Default Re: Replacing OEM With Brembo rotors question (Kalokohan)
alright thanks...good advice
Sijray21's Avatar
**EDIT**
damn repeat...
Modified by Sijray21 at 11:30 AM 8/17/2004
Old Aug 17, 2004 | 07:17 AM
Sijray21's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kalokohan &raquo;</TD></TR><TR><TD CLASS="quote">Don't forget the impact screwdriver, another headache that can be avoided.</TD></TR></TABLE>
omg...yes
fortunately after i used it the first time i never had a problem with those damn screws, but also get that damn screw that goes into the rotor hat so that taking off the rotor isn't a problem (ala no hammering). A little anti-seize on the back of the hat/hub and screws couldn't hurt either.
i know quite a few people who jsut don't put in those screws to avoid that problem.
Old Aug 17, 2004 | 07:23 AM
Solracer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sijray21 &raquo;</TD></TR><TR><TD CLASS="quote">
i know quite a few people who jsut don't put in those screws to avoid that problem.</TD></TR></TABLE>
I left them out on my car since I change rotors a lot, I didn't even bother with the impack driver, I just drilled the heads off, then took the rotor off nad un-screwed what was left
HBADGE
10
Oct 13, 2006 01:07 AM
Texas_EG
25
Sep 29, 2006 09:39 AM
Type - ARman
May 9, 2005 08:53 PM
kidaniel
Mar 6, 2005 05:06 AM
Accorddrver
Jul 24, 2003 05:32 PM
