What are the best e- cutoutīs ??
Well , i want to go with a e-cutout and i donīt know exactly which system have i to choose because i think there a some difference between quality and prize . So let me know what kind of e-cutouts are you guys driving and ho long with problems or not .
I remember reading some posts a while back of one of the companies breaking after short term use. I am sure if you search the achieves in FI you will find out which company it was.
E-cutouts have a poor service record. Try an m-cutout, works great for those of us with hoodpins and the hood release cable just dangling there, or the patience to fit another cable.
I picked up a 75mm (~3") Mustang TB that had a chip out of the slip fit area and bust0red TPS for $30, plan on using it to vent those surly turbocharged exhaust gasses on the new setup. FYI, the idea's half Speed Phreak's, props for the all night brainstorming sessions!
yeah i read some some post of the last months but i can not exactly see which e-cutouts are the best . I donīt want to drive with it when it leaks after a few miles .
@ mekkis : have you pics of it??
You have a few options. These are the ones I know of.
http://www.quicktimeperformance.com/
http://www.mccordcg.com/mpp/mpp.htm
http://www.dmhperformance.com/
I think the last one looks the best imo.
Yeah these e-cuts i have seen on the homepages too and i think that the last one , one of the best is because it looks heavier
Okay, here are the details on the last one....
*CNC Machined 6061-T6 aircraft grade aluminum body
*.375 diamiter 316 Stainless Steel Shaft
*Torrington Needle Bearings for years of trouble free service
*High torque gear motor
*Plug and play 16GA. Belden Wiring Harness
*Small black rocker switch is only .75" X .50"
*Proven Design with over 4 years of real world testing
*4 year replacement warranty!
PRICE:
$199 shipped with Flowtech
$179 shipped without Flowtech
Available in 4", 3.5", 3", 2.5",and 2"
Taken off their site
PRICE:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM »</TD></TR><TR><TD CLASS="quote">any links to the last one???? price???? im looking for one as well.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mekkis »</TD></TR><TR><TD CLASS="quote">I picked up a 75mm (~3") Mustang TB that had a chip out of the slip fit area and bust0red TPS for $30, plan on using it to vent those surly turbocharged exhaust gasses on the new setup. FYI, the idea's half Speed Phreak's, props for the all night brainstorming sessions!</TD></TR></TABLE>
i'd like to hear more about this!
I use A quicktime Cutout on my personal car.
Its not a bad peice overall.
I wouldnt mind trying some of the other ones listed here.
IMO it comes with a much nicer Wiring/switch setup than the rest of those.
They tend to fall apart in some situations. But it you can get a good mount for it, keep away from alot of vibration, etc... it will be fine.
I think they all will suffer from the same situations as the Labeled quicktime faults.
Have to use some silicone to seal it up, Loctite the bolts for some extra Precaution.
I have a mccord power plate, it's not on my car yet, but I've never seen anyone complain about them. The shaft is also welded to the butterfly, so that's less bolts to worry about falling out on you. Accordfreak used his for a while and never had a problem with it. . .
no leaks.
