H22 swap
Old Aug 16, 2004 | 11:29 PM
SpeedFreak77's Avatar
Default H22 swap
I am wondering if it is possible to use my manual transmission with an H22 motor? I currently have the F22 motor in my 94 Accord EX. By the way, I am new here so I am still learning my way around, FNG.
Old Aug 17, 2004 | 05:37 AM
FatJoe's Avatar
Default Re: H22 swap (SpeedFreak77)
searching would have showed you that YES itll work
Old Aug 17, 2004 | 06:51 AM
KGAccord's Avatar
Default Re: H22 swap (FatJoe)
yes, but you will eventually want/need the H22 tranny. the F22 tranny gearing is too tall and you will not accelerate as fast/ lose some fun factor. also, you have to consider the mileage on your current tranny and how it will stand up to the extra trq.
Old Aug 17, 2004 | 10:46 AM
SuperSlow's Avatar
You will be fine, just change your clutch and check your flywheel surface.
BrownProdigy
Feb 8, 2015 10:56 AM
Kris's turbo
Jan 25, 2012 09:52 AM
Jedi Mind
Apr 9, 2007 03:24 AM
accrdkid94
May 11, 2006 09:38 AM
Turbohatch
Dec 8, 2001 08:33 PM
