92 accord, radiator fan not coming on...
yea, this sux. could this be caused by my fan timer? what would be a good way to test the fan itself. thanks in advance!
p.s. i did do a search and found a couple things in the archive, but they were radiator problems. mine is good.
If you have a meter unplug the fan and see if you have voltage on the plug.If you do then it's the fan.If not I'm not sure about the relays or timers associated with it.Best bet would be to get a book with the schematic.
im having the same problem with my teg. try to run two wires off the battery to the fan plug in(on the left hand side of the fan and radiator) this will test your fan motor.
if that is not working. try replacing your fan switch. i picked one up from autozone for $20.
if not that. then it could be the wiring. so a short from the timing to the switch to the fan. just hope thats not it. that could take about a week to find.
good luck.
good luck.
