FS: Moroso Oil Pan for B-series including Oil Pick-up $320
I have Moroso Oil Pan & Oil Pick up used less than a week, purchased on 8/14/04.
due to emergency, i had to purchased this until i get stock replaced. I'm selling this before I make big *** dent, just like 3 of my headers & so forth. it holds 5 quarts of oil.
comes with 2 oil fitting for turbo cars.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integrasi »</TD></TR><TR><TD CLASS="quote">bump for expensive american sh*t</TD></TR></TABLE>
I'll give you a dollar because it isn't JDM.
What motor did you have this on, I'm asking because the oil pickup is different on some of the b-series stuff.
-PHiZ
-PHiZ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integrasi »</TD></TR><TR><TD CLASS="quote">oil pick-up is for all b-series w/ moroso oil pan. the way it's designed, it can only be used on moroso oil pan</TD></TR></TABLE>
Nope, different part numbers for... b16 and GSR/LS.
I think that's how it works.
-PHiZ
-PHiZ
actually gsr & itr have same oil pick-up. it's b16 & ls that's different.
mine are for gsr & itr, but i was told it can also be used on b16
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integrasi »</TD></TR><TR><TD CLASS="quote">actually gsr & itr have same oil pick-up. it's b16 & ls that's different.
mine are for gsr & itr, but i was told it can also be used on b16</TD></TR></TABLE>
Well I'm not trying to spread misinfo, I looked it up on moroso.com and they say:
Aluminum Kicked-Out Sump Pan,1994-98 Acura Integra 1.8L, VTEC & non-VTEC.
Note: Also fits Civic Si with 1.6 liter VTEC DOHC (model B16A3) using No. 24011 pickup.
VTEC EnginesPickup No 24010
Non-VTEC EnginesPickup No24011
I hope that clears things up, I hate to make things more confusing.
-PHiZ
-PHiZ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHiZ »</TD></TR><TR><TD CLASS="quote">
-PHiZ</TD></TR></TABLE>
is that mean it'll fit on to b16a1 & b16a2???? if you look at the label on the box, it says for b18 & b16 v-tec oil pan.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILuvJDMITR »</TD></TR><TR><TD CLASS="quote">what pickup do you have, and what do you mean by DENT?</TD></TR></TABLE>
moroso oil pick, which is to be used only w/ moroso oil pan. there is no dent.
moroso oil pick, which is to be used only w/ moroso oil pan. there is no dent.</TD></TR></TABLE>
i meant pickup for which motor, and there was mention of selling it before a "dent" in the origional post, were you refering to your wallet? lol or fear of denting the oil pan
i guess that make my next question; does it hang that low?
i guess i wilol be the only integra with a skid plate
they hang much as your stock header. the way it's designed is wider on the back.
reason: 1) before i dent the pan
2) eats up 5 qrt
2) eats up 5 qrt
