Gas Tank Door Wont Open =(
Well when I pull the level on the driver side floor it comes up but the gas tank wont pop open! So its stuck shut until I pry it open... Anyone got any remedies I cant figure it out!
Remove the cover by your seat and check the cable and latch. If everything checks out head on to the hatch and pull back the lining and you'll see where the gas door is and where the cable is run. Worse comes to worse you'd need to replace the cable which isnt too bad. You can pop the door from inside the hatch if you need gas right away.
Jer'rome
Honda Civic (2001 - 2005)
Feb 12, 2007 03:41 PM
mprznorth
May 1, 2006 06:36 AM
