2000 Teg ....what ecu to use?
I have a 2000 integra and i sold my ecu to put hondata p28 in.....now i am going back to stock and I cant find an ecu that will work. What are my options?
THanks
joe
THanks
joe
My Teg Helms says 98-99 and 00 use different ECU connectors - like the Civic's OBD2a and b.
The 99 Si ECU won't turn the fuel pump on because the fuel pump control wire is in the wrong spot - the 99 Si uses A16 for fuel pump control - your Teg uses A15.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR-T- »</TD></TR><TR><TD CLASS="quote">the immobilizer is only in the ecu i beleive....i had a p28 in there before and worked just fine</TD></TR></TABLE>
check your PM
check your PM
Cimburke23
14
Nov 18, 2013 03:18 AM
iRIDEdumped
32
Apr 25, 2005 06:34 PM
