welding stainless...
Old Aug 16, 2004 | 05:19 PM
jdm_ef9's Avatar
Default welding stainless...
do you need a tig to weld stainless? or can you do it with a mig? i need to get my new stainless exhaust welded soon. ive heard many different answers to this question, and was hoping someone could clear it up. thanks in advance.
Old Aug 16, 2004 | 05:27 PM
ICeDoUt's Avatar
Default Re: welding stainless... (jdm_ef9)
funny you should ask. I was just told by a welder of about 10 years that u can do it with a mig, but it doesn't look good. The welds are strong but it doesn't look nice. (i dunno what he ment, maybe discoloration?)If you tig welded it it would be strong and it would look good.
Old Aug 16, 2004 | 06:09 PM
bigTom's Avatar
Default Re: welding stainless... (ICeDoUt)
thermal exhausts are mig welded and they are stainless... it does look pretty bad... tig welded stainless just looks so much nicer
Old Aug 16, 2004 | 07:38 PM
SiRex91's Avatar
Default Re: welding stainless... (ek9t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9t &raquo;</TD></TR><TR><TD CLASS="quote">thermal exhausts are mig welded and they are stainless... it does look pretty bad... tig welded stainless just looks so much nicer</TD></TR></TABLE>
Yep, I just noticed that on thermal that was on a teg yesterday. They do 3 separate welds instead of just one clean continuous weld.
Old Aug 17, 2004 | 01:21 PM
SANKA's Avatar
Default Re: welding stainless... (SiRex91)
well tig is just easier to blend and make it look like one continous weld, were is it just alil harder with mig.
Old Aug 17, 2004 | 01:29 PM
b20turbojason's Avatar
Default Re: welding stainless... (SANKA)
i have welded on stainless and it looked like crap but i dont have that much experance. my buddy that has like 10 years experance welded some stainless for me it didn't look as good as i thought it would have. so yeah i guess that is true that mig on stainless doesn't look good. but then my buddy also stick tig welded some stainless and it didn't look alll that hot either untill he just used the wand by its self to bond the two pipes together and that is when it looked bad ***. but i have seen stick tig welds that have looked really good though.
Old Aug 17, 2004 | 02:16 PM
H23vtecEG's Avatar
Default Re: welding stainless... (b20turbojason)
damn ti i want pix
Old Aug 23, 2004 | 01:40 PM
Canuk_SiR's Avatar
Default Re: welding stainless... (H23vtecEG)
it all depends on the thickness of the material you're welding. Stainless has the tendancy to 'burn' if you're using too much heat, and the downside to mig is that depending on the wire you use, you'll most likely be putting in more heat as compared to tig. I've done alot of mig on stainless, mostly thicker plate (1/4" and up) and most times the bead will look almost like it was welded with a stainless rod. make sure you're using the proper shielding gas. C02 with a heater on the bottle is what you want for stainless mig.
Old Aug 23, 2004 | 05:29 PM
Bnjmn's Avatar
Default Re: welding stainless... (Canuk_SiR)
I've MIG'd stainless piping with good results. I actually felt my mig welds on stainless tubing were better than my welds on aluminized steel (prepped).
In any case, I found the technique was very similar to welding mild steel and the beads looked good as well, they just stood "up" a little bit. I used a tri-mix of argon/co2/helium and stainless wire.
Ben
Cyber ITR
Welding / Fabrication
22
May 4, 2008 11:24 PM
wunfstmax
May 28, 2007 10:10 PM
TIGboy
Dec 16, 2005 09:11 AM
RMF
81
Sep 18, 2005 11:39 AM
icucnme
Jan 31, 2005 08:19 PM
