HELP!!! SUSPENSION- JDM eg/type r suspensioon to EJ/EK?
Old Aug 16, 2004 | 03:05 PM
f22b-dohc's Avatar
Default HELP!!! SUSPENSION- JDM eg/type r suspensioon to EJ/EK?
we have a set of CUSCO suspension from an JDM ITR/ eg ...
it came with the LCM but is short
installing it on a 2000 civic.
on the eg/eh it bolts on....
any idea on what LCM should be used?? SOL?
http://www.jdmplace.com/Images...8.jpg
Old Aug 16, 2004 | 03:47 PM
TallAssFilipino's Avatar
Default Re: HELP!!! SUSPENSION- JDM eg/type r suspensioon to EJ/EK? (f22b-dohc)
For the JDM EG or DC? Which is it? The IT-R will have the diff' rear LCA's. Have you tried looking into the CT-R rear LCA's? Otherwise, you might have to use the standard rear struts.
Old Aug 16, 2004 | 06:23 PM
f22b-dohc's Avatar
Default Re: HELP!!! SUSPENSION- JDM eg/type r suspensioon to EJ/EK? (TallAssFilipino)
tanginangshit... im flip too...diego area???
aites, heres more info
it came off an JDM itr...96
i bought a tein setup and all i had to do was buy the LCA....bolted right on the 92 civic
now i bought the cusco setup and noticed that the LCA is longer on this ej (EK) 2000 civic....
MY QUESTION IS WTF lca can i USE???????
BTW THESE LOOK SICK... UPPER PILLOW BALL MOUNTS, ADJUSTABLE PERCH, 5 WAY DAMPENING, ADJ HEIGHT AND ALL ALUMINUM BODY..
Old Aug 17, 2004 | 09:05 PM
f22b-dohc's Avatar
no one knows??? WTF
Old Aug 19, 2004 | 06:36 PM
Yeah, from Daygo... North County.
Daym! Can't find my EK rear-lower tie bar to compare to my EG rear-lower tie bar. But I could have sworn the EK tie bars are shorter than the EG tie bars making the EK have the longer rear LCA's than the EG's. Plus, I recently did a complete 4-wheel disk brake conversion on my buddy's EK and I remember noticing how long the rear LCA's.
Anyway, the differences between the suspensions on the 92-95 Civic's and the 96-00 Civics are:
· Front-upper control arms
· Rear-lower control arms
· Stiffness in bushings
· Strut/spring rates
IT-R rear-lower control arms are different as well. Never seen the CT-R rear-lower control arms before.
Which style do your control arms look like...
or...
Old Aug 21, 2004 | 12:14 AM
scummmybear's Avatar
Hey! Sorry for hijacking the thread, but f22b-dohc started this thread for me...
Here's what I've got:
I'm driving a 2000 Civic 4-door (yes, sedan - boooooooooo)
the rear LCA looks similar to the picture on top,
but the control arm that came attached to the Cusco is similar to the lower picture
my current LCA on my car right now seems to also be around 2" longer from the outter most bolt-holes (I don't know what they're called) than the JDM Control arms that came with the cusco's...
hope that helps a bit... If I can't find a good way to get these Cusco's to fit, I'll be looking at selling them I guess.
Old Aug 23, 2004 | 02:26 AM
Default Re: HELP!!! SUSPENSION- JDM eg/type r suspensioon to EJ/EK? (scummmybear)
Well, you can't use any EG/DC LCA's. You'll have to stick to the LCA's for your year Civic. They're longer. It seems your rear struts and LCA's are for an IT-R. If they made a CT-R rear LCA that is like the bottom picture, but longer, then you'll need those. Otherwise, you'll have to use the standard style rear shocks that look like the top picture.
Barklaya
Jun 13, 2018 10:41 AM
Momentum
Suspension & Brakes
May 6, 2009 10:11 PM
KillBot
Mar 12, 2005 10:56 AM
Screamer
Sep 2, 2004 11:10 AM
evil_elmo
Jan 16, 2002 11:36 PM
