any HOW TO's on installing the ITR cluster in a EG?
Old Aug 16, 2004 | 09:01 AM
JinDIESEL's Avatar
Default any HOW TO's on installing the ITR cluster in a EG?
check this out. anyone know anyone that can provide a wiring and fabrication guide for the install of the ITR gauge cluster in the EG?
Old Aug 16, 2004 | 09:04 AM
95sihb's Avatar
Default Re: any HOW TO's on installing the ITR cluster in a EG? (JinDIESEL)
More then 99% sure it's the same as anyother integra cluster, it does look nice but if you look closely there still is gaps around the cluster,
Old Aug 16, 2004 | 09:32 AM
cxSHOE's Avatar
Default Re: any HOW TO's on installing the ITR cluster in a EG? (95sihb)
depending on what year jdm itr gauge you get there will be about 4-5 wires that will need to be hooked to different colored wires the rest are hooked to the same oem wire. and yes you can get the dimmer and srs lights to work as they should.
Old Aug 16, 2004 | 10:08 AM
Arsenal's Avatar
Default Re: any HOW TO's on installing the ITR cluster in a EG? (cxSHOE)
So if its a USDM one it will hook straight up?
Old Aug 16, 2004 | 10:19 AM
Kewl_Black_Civic's Avatar
it'z just somethign "Different"...
the speed goes higher than normal mine goes as high as 220 kilometer but i think that one showed 240!?
i might be mistaken!
Old Aug 16, 2004 | 10:27 AM
95sihb's Avatar
Default Re: any HOW TO's on installing the ITR cluster in a EG? (Arsenal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arsenal &raquo;</TD></TR><TR><TD CLASS="quote">So if its a USDM one it will hook straight up?</TD></TR></TABLE>
No it will not , You must re-wire the cluster in-order for it to work with the civic , thats any Spec
Old Aug 16, 2004 | 11:10 AM
crx_88_si's Avatar
FYI that car is from Italy.. i just saw it in a thread about some1 going to F1 tracks in Italy.
Old Aug 16, 2004 | 11:18 AM
G3NR8's Avatar
Default Re: any HOW TO's on installing the ITR cluster in a EG? (crx_88_si)
http://patriot.net/~merritt/
Go to that link, then to "tech". Theres an ITR cluster how to
Old Aug 16, 2004 | 11:27 AM
Blue-Civic-Hybrid's Avatar
Loved
Sweet interior....
Old Aug 16, 2004 | 11:31 AM
JDMb18civic's Avatar
Default Re: any HOW TO's on installing the ITR cluster in a EG? (G3NR8)
u gotta wire everysingle wire from the civic harness to the integ cluster harness...
its a bitch!!!!!!!!!
but it looks tite..
Old Aug 16, 2004 | 12:10 PM
Loved
What kind of steering wheel is that? It looks like an S2k wheel....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JinDIESEL &raquo;</TD></TR><TR><TD CLASS="quote">check this out. anyone know anyone that can provide a wiring and fabrication guide for the install of the ITR gauge cluster in the EG?
Old Aug 16, 2004 | 12:36 PM
Kalokohan's Avatar
New User
Default Re: any HOW TO's on installing the ITR cluster in a EG? (JDMb18civic)
The check engine light is tight too...
Old Aug 16, 2004 | 01:09 PM
Arsenal's Avatar
Default Re: any HOW TO's on installing the ITR cluster in a EG? (Kalokohan)
The steering wheel is an Isotta form Italy.
More info on the car is on another thread about an EG at The 'ring
Old Aug 16, 2004 | 01:51 PM
KiD Fr0m Da 516's Avatar
yeah i saw this vid also and i want to know, it looks like a clean fit also
Old Aug 16, 2004 | 02:12 PM
TyPe-R6's Avatar
Good info G3NR8
Old Aug 16, 2004 | 02:14 PM
CivicSiRX's Avatar
i install a gsr cluster in my car before and let me tell u, the wiring is a nightmare, u have to tap into all the civic wires, so u need integra cluster plugs, then you have to ghetto rig the cluster to fit in, thus leavin u gaps and what not.
i have seen a member on here that took the civic plastic cover off and bondo it to the integra cluster, thus making the integra cluster look stock but requires some tedious work. go look into the archives top of this civic forum on page2, u will find more info on this mod there.
Kowal123vtec
Mar 31, 2019 12:15 AM
9sihatch3
Sep 23, 2005 01:56 PM
Jdm*EG
Jul 28, 2004 07:18 PM
citrusdrop
Nov 6, 2003 12:43 PM
JDMlyfestyle
Jun 24, 2003 11:00 PM
