first gear won't go in!!!! help~~!!
Old Aug 16, 2004 | 12:02 AM
92eh3si's Avatar
Default first gear won't go in!!!! help~~!!
my friend's 95 delsol is having some problem..
it's got a stock motor (d16z6) and i don't exactly know what happened but he told me that 1st gear wouldn't go in(no free play in neutral), sometimes the shifter don't even wanna move, would it be just the synchros? shift linkage problem?
Old Aug 16, 2004 | 02:43 AM
OpTiX619's Avatar
Default Re: first gear won't go in!!!! help~~!! (92eh3si)
check shift linkage first.... maybe something got caught in them or something...
Old Aug 16, 2004 | 01:02 PM
92eh3si's Avatar
anybody else has an opinion??
help please~~!!
Old Aug 16, 2004 | 01:07 PM
PLAN:B's Avatar
Default Re: (92eh3si)
My first guess is the linkage also. If it's in neutral the shifter should be able to wiggle left and right no matter whats wrong with the inside of the tranny. If it doesn't something is in the way.
Old Aug 16, 2004 | 01:42 PM
.RAven's Avatar
Default Re: (mEKsican)
When you start the car up is it in nuetral? If yes and shifter doesn't wiggle then you may have something keeping the shifter from moving. If you start it up and the car is in gear then you my friend may have a bad throw out bearing. let me know any more symphtoms.
Old Aug 16, 2004 | 01:47 PM
I8Stang's Avatar
Default Re: (prime weaksauce)
could be clutch master cylinder.....check your fluid..
Old Aug 18, 2004 | 01:56 PM
92eh3si's Avatar
aite.. thanks guys.. bouts to tell him to check his shift linkage.. but most of the time, it wiggles left and right i believe, but i will tell him to check the linkage first and will post more if there is any more problem.. thanks
Rolo30
Transmission & Drivetrain
12
Apr 25, 2009 03:19 PM
RMX_EF9
37
Jun 18, 2007 02:20 PM
konvikt
Jan 20, 2007 08:01 PM
90dxhatchback
Jun 30, 2005 02:45 AM
bOOsTiNSoHcVtEc
May 21, 2003 03:25 PM
