will this motor bolt right up to this tranny??
Old Aug 15, 2004 | 09:06 PM
rolledthatho's Avatar
Default will this motor bolt right up to this tranny??
as many of you know i was gonna go the FI route and was trying to swap but im just gonna get an 86 carbed HF ew1 motor my question is
will that bolt up to an 87 auto tranny that comes stock in a civic sedan
86 carbed HF bolt right into and 87 carbed civic automatic tranny
making my combo 86 HF motor with 87 auto civ tranny
ALSO an HF will bolt right in motorwise wouldnt it?
thanks and sorry if this is confusing
Old Aug 15, 2004 | 10:05 PM
bizump
Old Aug 15, 2004 | 10:11 PM
Malgerus's Avatar
Default Re: (rolledthatho)
Not sure if this helps, but I know the mounts are completely different...
Old Aug 16, 2004 | 12:54 AM
they may be diff, hopefully they will work, does anyone know if an 86 HF motor will bolt right in and if it will fit my tranny
Old Aug 16, 2004 | 08:02 AM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
Default Re: (Mr. S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. S &raquo;</TD></TR><TR><TD CLASS="quote">Not sure if this helps, but I know the mounts are completely different...</TD></TR></TABLE>
Unless I am greatly mistaken, the mounts on 86 and 87 models (except 4wd wagons) are exactly the same regardless if they are carbed, fuel injected, M/T, or A/T. It is only the 88+ cars that have completely different mounts.
The 86 HF engine should bolt up to your 87 auto tranny just fine. If you were using a manual tranny then you would need to use the starter that matches your flywheel, i.e. HF starter with HF flywheel or DX/Si starter with DX/Si flywheel, but your auto flex plate should bolt to your HF crank no problem. It might be best to go thru the wiring and vacuum hose diagrams in the 87 service manual over on the rpr site to see what is different. That will tell you far more than we ever could.
Old Aug 16, 2004 | 09:06 AM
wtsexton's Avatar
Should work but I don't want to THINK about how slow it'll be.
My 87 DX Auto is slow already!
Old Aug 16, 2004 | 09:39 AM
Malgerus's Avatar
Default Re: (wtsexton)
My bad, for some reason I thought he meant an 88 auto tranny
Old Aug 16, 2004 | 10:41 AM
well thats the thing, even rpr himself, or whatever. lol isnt 100 % sure it will work
http://www.redpepperracing.com...11503
B18C1-ED8
Jun 4, 2006 11:56 AM
EncoEvolution
Sep 29, 2005 05:07 PM
Muckman
13
Feb 25, 2005 07:24 AM
busychild
Oct 1, 2004 11:32 AM
crxdriver89
Apr 28, 2004 10:17 PM
