srs light trick not working
Old Aug 15, 2004 | 08:17 PM
Brakiss's Avatar
Default srs light trick not working
ok i did the 4 step trick about 15 times, and for some reason instead of my srs light flashing twice to let me know that it is reset, it flashes constantly till i turn the car off. I wait 10 seconds and start it, and it stays on, any help?
Old Aug 15, 2004 | 11:56 PM
Brakiss's Avatar
Default Re: srs light trick not working (Brakiss)
come on peoples, i need some help
Old Aug 16, 2004 | 02:09 AM
2+2=5's Avatar
the step to reset the light will not get rid of the light if there's actually sometime is wrong(SRS system) with it.
Old Aug 16, 2004 | 04:12 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: srs light trick not working (2+2=5)
yep, if there is still something wrong with the system then the light won't go out.
For example, someone said that if your airbags blow you need to replace both the airbags and the module. So, if the bags blow and you replace only the bags then your light won't out because you haven't replaced the module yet.
Old Aug 16, 2004 | 05:16 AM
Justin Klemgold's Avatar
Where's the trick at? I would like to read that...
Old Aug 16, 2004 | 05:33 AM
H-T Order of Merit
Default Re: (Justin Klemgold)
search for "SRS light" or "SRS reset" in the archives. I know I've posted the instructions a couple times as well as some other people.
Old Aug 16, 2004 | 05:35 AM
H-T Order of Merit
Default Re: (TouringAccord)
actually, here you go. This is what I posted in another thread.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord &raquo;</TD></TR><TR><TD CLASS="quote">This is someones step-by-step that I saved a while ago. Can't remember who wrote it but here it is.
Erasing the DTC memory
1) Turn ignition switch off
2) Connect the scs service connector to the MES connector. Do not use a jumper wire
3) Turn ignition switch to on
4) The SRS indicator light will come on for about 6 seconds, and then go off. Remove the SCS service connector from the MES connector within 4 seconds after the light comes on
5) The SRS indicator will come on again. Reconnect the SCS service connector to the MES connector within 4 seconds after the light comes on.
6) When the SRS indicator light goes off, remove the SCS service connector from the MES connector within 4 seconds.
7) The SRS indicator light will blink 2 times indicating that the memory has been erased
8)Turn the ignition switch to off and wait for 10 seconds.
I know what your thinking. WTF is the MES connector? Good question. Its up under the steering wheel. Above and behind the scan tool connector (where you jumper it to get CEL codes)
Hope this helps you.</TD></TR></TABLE>
edit:
here's the link I copied that from.
https://honda-tech.com/zerothread?id=901907
Old Aug 16, 2004 | 10:19 AM
Brakiss's Avatar
there is nothing wrong though, i didnt blow the bags, i just disconnected the cluster.
Old Aug 16, 2004 | 10:37 AM
H-T Order of Merit
Default Re: (Brakiss)
I don't know, maybe your just not getting a complete connection while doing the procedure. I heard they can be really fusy if you try doing it with a paper clip.
Old Aug 16, 2004 | 11:05 AM
Brakiss's Avatar
im using 2 wires with prongs attached to clip into the plug, it completes then blinks constantly, and when i turn the car on, it flickers like it wants to turn off, but doesnt
Old Aug 16, 2004 | 12:57 PM
venumnos's Avatar
i have the same problem with mine after i disconected the clust and put it back the srs light wont go off ...
Old Aug 16, 2004 | 04:10 PM
Brakiss's Avatar
ttt
Old Aug 16, 2004 | 11:55 PM
ben95ex's Avatar
jump the service connector under the glove box and turn the key to on. count the blink pattern the srs light makes and call honda, or post it on here if anybody has a helms they'll tell you what the code means.
i thought mine just needed a reset and tried the "trick" about 10 times, finally pulled the code and turned out it was a faulty SRS control unit... cost to replace: $600. then i took the SRS light out of the dash and sold it to a private dealer.
Old Aug 17, 2004 | 12:20 AM
Brakiss's Avatar
good call, i was wonderin if i could do that
Old Aug 17, 2004 | 01:00 AM
Brakiss's Avatar
which connector? i jumped the one i do for the cels, but it just turned on the cel. There is another blue connector right next to it, but it is 3 wire
jdmrida
Nov 21, 2008 08:58 AM
wardseg6
Honda Civic (2001 - 2005)
Jul 21, 2007 11:40 PM
P3T3R
Apr 17, 2005 09:36 PM
