Car will not start, it is fuel related.
Ok, crazy thing...my second prelude has this thing about not wanting to turn over. It will crank and crank but will not turn over. I can take of the intake and spray some gas in her and she will crank. Is this an injector issue? I just put this motor in the car. The car use to house my h22 and it never did that, so i am guessing it is not fuel pump, injector resistors or anything. Ideas please.
btw...it is a stock h23
Guest
Posts: n/a
pull your service bolt on the fuel rail. crank and see if it starts spraying your engine bay with fuel. if it does, it's more than likely your injectors. This is of course only true if you know for a fact it is a fuel problem.
yeah, you can hear the pump buzzing when you turn the key on. I had an h22 in this car at one time and it never did this. only when i put an h23 that i had back into it. So my guess, it is the injectors.
AdamJ2
Jul 5, 2008 12:16 PM
