how long do koni yellows last?
Old Aug 15, 2004 | 04:29 PM
clean00LUDE's Avatar
Default how long do koni yellows last?
hey guys ive had my koni shocks for like 2 years now with eibach pro kit springs, and was just wondering how long i will be good riding on these.
also you know the **** to adjust the stiffness of the shocks, i havnt messed with it for 2 years either, am i supposed to?
thanks
Old Aug 15, 2004 | 09:29 PM
Default Re: how long do koni yellows last? (clean00LUDE)
anyone?
Old Aug 15, 2004 | 09:37 PM
SuperSlow's Avatar
Strange question. Depends on the driver and terrain.
Old Aug 15, 2004 | 10:17 PM
blk97lude's Avatar
Default Re: how long do koni yellows last? (SuperSlow)
yea it depends how u use it.. but they last a long time.. mine have been in my car for like.. 3 1/2 years and its still good
Old Aug 16, 2004 | 08:36 AM
luder94-ChrisA's Avatar
Default Re: how long do koni yellows last? (blk97lude)
With the Eibach Pro-kit & not too much of a drop, they should last a very long time. However, if you drive around with them on full stiff, you will shorten the life-span.
If you running higher spring rates, they'll wear out faster. I'm running Ground Controls with my Konis - 400 Front, 550 Rear & I'll probably be getting a revavle sometime in 2005
Old Aug 16, 2004 | 10:21 AM
Default Re: how long do koni yellows last? (luder94si)
thanks guys
Old Aug 16, 2004 | 07:39 PM
Adam.'s Avatar
I believe they also come with a lifetime warranty. Limited of course.
Old Aug 16, 2004 | 07:52 PM
del_parker's Avatar
i've had mine since '01 and they're doing fine.
Old Aug 16, 2004 | 08:39 PM
v4lu3s's Avatar
RTFM
i called koni about having mine rebuilt/revalved, they suggested jstu buying new ones sicne the cost would be near the same once hsiping is fifured in, im on a used set with about 30k miles on neuspeed race sprigns and full stiff and they are still working great.
Old Aug 17, 2004 | 12:26 AM
del_parker's Avatar
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">i called koni about having mine rebuilt/revalved, they suggested jstu buying new ones sicne the cost would be near the same once hsiping is fifured in, im on a used set with about 30k miles on neuspeed race sprigns and full stiff and they are still working great.</TD></TR></TABLE>
typically you get the shock revalved to handle a stiffer spring rate, which koni won't warranty.
c'mon
Suspension & Brakes
Jul 24, 2009 11:31 PM
joe_black
Suspension & Brakes
Jul 7, 2005 07:54 AM
iLOVEmyEMone
Suspension & Brakes
Jun 2, 2005 02:05 PM
Sportmode
Apr 2, 2003 12:32 PM
wuhungsixxx
Jul 31, 2001 05:42 PM
