SOHC ZC probs, possible fuel system
Old Aug 15, 2004 | 04:14 PM
stealth civic's Avatar
Default SOHC ZC probs, possible fuel system
OK, 91 crx si with sohc non-vtec zc. It runs shitty while warming up, but once the temp needle moves, its idles perfect. But even when its warm, it stumbles hard on acceleration. Open the throttle and it just rumbles for several seconds until it starts to rev. Once I get the rpms up, i can hold it there without any problems. Anyone have any ideas? Oh yeah, I used a DX TPS, is there any mods I need to do. Its not throwing any codes, fuel pressure is good, gas is good, new fuel filter, fuel pump is good, so Im just kinda lost on this one. Thanks for any help guys.
-Matt
Old Aug 15, 2004 | 04:19 PM
cbrodac0424's Avatar
Default Re: SOHC ZC probs, possible fuel system (stealth civic)
your might want to try replacing the tps with a si or replace your map sensor good luck just a guess correct me if i am wrong probley am
Old Aug 15, 2004 | 06:18 PM
Default Re: SOHC ZC probs, possible fuel system (cbrodac0424)
Map sensor is good, and I get no CELs. Any other suggestions.
Old Aug 16, 2004 | 01:10 AM
BUMP
Old Aug 21, 2004 | 03:45 PM
C'mon guys, need some help with this. Any ideas?
Old Aug 22, 2004 | 05:36 PM
builthatch's Avatar
MiG-21 superfan
How are your grounds, coil, ignitor, etc? Is your spark strong? Do you have another ECU to try? Another distributor? What do the plugs look like?
Old Aug 22, 2004 | 07:53 PM
Default Re: SOHC ZC probs, possible fuel system (builthatch)
Oh, i found the prob, the compression variates by 40 PSI between cylinders 3 and 4.
cjhmarine
Jan 16, 2010 10:01 PM
JasonKarl
Apr 21, 2008 09:53 AM
h22_crx
Apr 4, 2006 04:48 AM
polycrx
Apr 11, 2003 09:08 AM
