Storing a Turbocharged car
Old Aug 15, 2004 | 02:47 PM
accordselux's Avatar
Me Gusta History
Default Storing a Turbocharged car
Well now that my turbo is being installed in my Accord, I'll be leaving for college. I'll drive it periodically until after thanksgiving, and then it will be in storage for 3-5 months. Should I give my car any particular care since it will be turbocharged in storage? Drain the oil, or anything special?
Thanks in advance!
Old Aug 15, 2004 | 02:58 PM
boosted92's Avatar
Default Re: Storing a Turbocharged car (accordselux)
Don't drain the oil, the metal surfaces may become exposed to water and can rust. Change the oil right before it goes into storage to remove any contaminants from combustion in the oil to prevent corrosion. I would start it periodically as well.
Old Aug 15, 2004 | 05:16 PM
second edition's Avatar
Default Re: Storing a Turbocharged car (boosted92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted92 &raquo;</TD></TR><TR><TD CLASS="quote"> I would start it periodically as well.</TD></TR></TABLE>
i wouldnt.
i stored my car all last winter(nov-mar) and it started right up like i had just drove it.pull the battery,fill up the tank,change the oil and put a cover on her and say your goodbyes.
Old Aug 15, 2004 | 05:19 PM
Hayasa15's Avatar
i am not sure about filling the gas tank put you need to put fuel stabilizer in the gas to keep it good.
Old Aug 15, 2004 | 05:23 PM
Default Re: (Hayasa15)
i put stabil in it and filled her up.the more gas in the tank, the less room for condensation
Old Aug 15, 2004 | 05:26 PM
ChaseIntegra's Avatar
Default Re: (second edition)
Yes, you wanna fill it up and pour in some Stabil.
Old Aug 15, 2004 | 05:31 PM
pngfolife's Avatar
Make sure to prime the motor before starting it for the first time. Pull all sparkplugs, pull ignition fuse, and crank the engine until the oil light goes out.
screename
Sep 21, 2006 07:52 PM
97dc2
Aug 3, 2005 09:39 PM
y0y0
Apr 10, 2005 01:13 AM
Y2A
Nov 17, 2004 05:31 AM
is3oo
Jun 6, 2004 06:49 AM
