cruise control
for some reason i cannot get my cruise control to work, when i push the dash button and the button on the steering wheel the light comes on saying that cruise control is working, but it is not holding speed, where would i start to fix this, thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Behan »</TD></TR><TR><TD CLASS="quote">Check the vacumm lines going into the cruise control unit. The cruise control uses vacumm to hold the throttle at a certain position. </TD></TR></TABLE>
im with him
im with him
Most likely it's the switch that turns off cruise control when you brake.
You can find this under the brake pedal, you'll have to lay on your back and look up underneath your pedal, unscrew it and adjust it so the switch is pushed in when you're not braking.
When you brake, the pedal arm moves away from the switch and this tells your CC you're braking.
KDoGx504
Dec 17, 2005 08:52 PM
