b16 pistons in a LS block is it possible
Is it possible to put b16 pistons in a ls block for my ls vtec. I guess if its possible it'll bump up the compression a little. Does anyone have it and what kind of power is it putting down. and will balancing the crankshaft in my ls block help any.
i put in b16 (p30) pistons into my ls build up. with the ls head its making about 11:1 compression. go to http://www.c-speedracing.com/h...c.php to find out what kind of compression you will be running with the head you will use.
i believe they press right into the wrist pins
check this link out http://cgi.ebay.com/ebaymotors...=WDVW
JDMCRX
Mar 27, 2009 11:11 PM
Roy2377
Jan 12, 2005 07:50 PM
