HELP!!! Tial Wastgate 44mm V-BAND is not SEALING, anyone else experienced this.
Old Aug 15, 2004 | 11:03 AM
fipracing_com's Avatar
Default HELP!!! Tial Wastgate 44mm V-BAND is not SEALING, anyone else experienced this.
Problem solved thanks
Modified by fipracing_com at 4:49 PM 8/15/2004
Old Aug 15, 2004 | 11:16 AM
Kwuaymaikrup's Avatar
Default Re: HELP!!! Tial Wastgate 44mm V-BAND is not SEALING, anyone else experienced this. (fipracing_com)
Did you put the little ring in the bottom of the WG when you installed it? It sits on the valve and forces it to seal once the WG is installed.
Old Aug 15, 2004 | 11:19 AM
Default Re: HELP!!! Tial Wastgate 44mm V-BAND is not SEALING, anyone else experienced this. (Kwuaymaikrup)
You can see what I am talking about just to the lower left of the WG.
Old Aug 15, 2004 | 11:27 AM
Jared's Avatar
he is using the 44mm vband, does it even have a fire ring since there is no bolt up flange?
Old Aug 15, 2004 | 01:02 PM
Default Re: HELP!!! Tial Wastgate 44mm V-BAND is not SEALING, anyone else experienced this. (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">he is using the 44mm vband, does it even have a fire ring since there is no bolt up flange?</TD></TR></TABLE>
Sure does. I am running the 44 V-band as well. I just couldn't find a picture of the 44 with all the accessories.
deucedeuceEK
May 28, 2008 03:00 PM
GenIIIMrDuece
Welding / Fabrication
Nov 30, 2007 06:08 AM
hondaapi
Nov 15, 2005 05:11 AM
Dammit_Dan_954
Feb 2, 2004 11:06 AM
