FS: HAYAME FULL COILOVERS - RSX
I have a set of brand new Hayame coilovers for RSX.
This is an exerpt from the ClubRSX forum on the Hayame coil overs:
The system comes with 3 locknuts.
advantage of 3 locknuts: You know how most coilovers, lower you go worse the ride. Well that’s because with coilovers such as tein, you adjust the spring perch(the thing the spring sits on) to lower the car. When you lower the car 2" with tein's your basically compressing the shock 2" all the time, which puts added stress on it. With the hayames you’re not adjusting the perch but the actual length of the strut. This allows the shock to retain full stroke and gives you the same ride at 2" as you would at stock height.
Top Mount: This allows ease of installation. Basically just take out the old struts and put in the hayames. No need to worry about compressing the springs, what parts you need from the stock struts, whether your 01 needs new mounts, etc... It just makes installation a breeze.
Also when receiving the coilovers I saw something I didn’t see in the pictures. There isn’t a camber plate BUT they made the hole for the top bolt wider so that you can adjust the camber that way without using a (front) camber kit.
Another thing is they have 'spring isolators'. People with teins or b&g sometimes complain about clanking noises. The spring isolators eliminate the noises often found with coilovers.
There are so many little details hayame paid attention to. It may not have damper adjustability but it has all these other features that the $1200 coilovers don’t have. All for $650, you can’t beat it... Best bang for buck hands down.
Ok so I finally got the fronts on. Right now i have the fronts at 2.25" and the rear at 2.5"(basically exactly the same as neuspeed race). Drove my car to work(the roads are really badd and I practically memorized the streets so it put them to the test) and I have to say they ride really nice. There's a couple places where I cringe going 15mph but with the hayames I can take them at 35mph without having to. The rear is slightly softer than what i'm used to but i'm sure adjusting the preload on the springs will fix that(just raise the perch up to compress the springs more). I'll probably play with that tonight if I can and will probably drop it down so that I tuck in a week(cause my dad has to use my car on thursday). I should probably be going down to a 2.5-3" drop eventually with my 18s. Oh and best of all NO MORE BOTTOMING OUT!!!
$650 shipped
pls pm me if interested?
$650 shipped
dragneon
Jun 14, 2007 12:52 AM
