who can fab this: swaybar mount bearing
Old Aug 15, 2004 | 09:45 AM
suspendedHatch's Avatar
Default who can fab this: swaybar mount bearing
Here is a conceptual drawing of what I want.
This is the passenger-side swaybar mounting bracket. I will of course want a corresponding driver's side mount.
Basically I want a ball bearing, like a tiny wheel bearing or skate board wheel bearing, the inside diameter being the OD of the swaybar. The mounting hardware needs to be fairly strong as to resist flex under load, and it will look similar to the Progress swaybar mounting brackets so that the subframe doesn't tear out. The dimensions will be determined by the surface of the subframe where it mounts. My car is an EG.
This is what the Progress swaybar mounts look like:
I will want three mounting points cuz I want to include the LCA pivot bolt.
Modified by shaundrake at 7:28 PM 8/15/2004
Old Aug 15, 2004 | 10:26 AM
nonsense's Avatar
Default Re: who can fab this: swaybar mount bearing (shaundrake)
you can buy pillow blocks
http://www.1speedway.com/Swaybar_Arms.htm
Old Aug 15, 2004 | 10:54 AM
Default Re: who can fab this: swaybar mount bearing (nonsense)
I see them, but I'm not sure what they are. Just a bushing, right? I want a bearing.
Old Aug 15, 2004 | 08:19 PM
turbo83lude's Avatar
how you gonna slide the bearing onto the sway bar? The bearing might not beable to slide onto the bar with the bends in it.
Old Aug 15, 2004 | 08:51 PM
Default Re: (turbo83lude)
Bar will be slid into the bearings and then custom bent.
Or I'll just use a straight bar with seperate arms. Haven't decided yet.
Modified by shaundrake at 7:19 AM 8/16/2004
Old Aug 15, 2004 | 09:28 PM
JustChou's Avatar
Default Re: (shaundrake)
Yeah, looks to me like pillow blocks are the way to go. You can purchase them through Grainger, McMaster Carr, MSC Industrial, or any given Industrial supplier in just about any metric or standard ID you can think of.
Old Aug 16, 2004 | 05:22 AM
89civicdx's Avatar
Default Re: (JustChou)
Use the pillow blocks its a lighter more reliable mount + its cheap
If you wat the bearing mount you can buy them already made as I believe they make them for small drive shaft mounts for industrial stuff.
Old Aug 16, 2004 | 10:24 PM
L-CON1's Avatar
why would you want to use a bearing? go to http://www.jerrybickel.com and look at their sway bar kit maybe that will give you a good idea of what your looking for. this kit wont work its the only pic i can give you off hand to help you in your project!
Modified by fab1 at 10:58 PM 8/17/2004
B serious
Apr 15, 2012 11:14 AM
CRwreck
Suspension & Brakes
Jul 8, 2009 08:03 PM
beanbag
57
Mar 19, 2009 12:12 PM
EG-Honda
12
Nov 7, 2007 12:35 PM
SilverDc2
Jan 5, 2006 10:25 AM
