jdm d15b wiring harness
it kinda depends, in japan the jdm d15b vtec ran a 1 wire o2 sensor. here ours run a 4 wire. thats the only real difference to a z6. or even if you have a dx, its very easy to run the vtec wires. but essentialy yes, a z6 will work.
yeah pick up a d16z6 harness... should be plug and play as long as you run a 4wire o2 sensor. i believe the p08 ecu will take both 1 and 4 wire o2's...
even a cx or dx harness is fine. then you would have to run vtec and crap... no biggie at all.
the p08 ecu will not run a 4 wire o2. so if you are getting a jdm harness, get the p08 ecu. if your using the z6 harness, get the p28, very simple
SlaMMedB16
Feb 25, 2008 12:56 PM
Untamed_Hatred
Jan 29, 2008 09:59 AM
madswapper
Mar 28, 2005 07:51 PM
RicedREX
27
Aug 3, 2004 10:57 AM
