Does power steering pump fit B16 conversion in CRX??
Almost completed B16 conversion.....last day of fitting and can't seem to get the power steering pump to fit on B16. The pulley seems to interfere with the power steering oil cooler lines plus the fluid line from the steering rack does not reach round the motor to the pump!!!!!!!
Who has done the B16 conversion and has managed to fit the pump?
Is the only option to run without the power steering?
How heavy is the steering without the assistance?
**** power steering, who needs the extra weight
. theres really no difference in steering....well, only when your not moving
im am running in to the same problem and inm still working on it. some people like to drive there car daily and want power steeering. if you are worried about saving weight then go on a freaken diet, a power steering pump and fluid and hoses only wiegh about 15 lbs. big deal...........
Modified by honda parts pro at 7:57 PM 9/18/2004
probably have to get the P/S line from a comparable car that came with a b series motor. example EF8, EF9 maybe even a motor that had a DOHC ZC in it.
personally i would try to find a b16 steering pump and line
JohnCRX
Aug 15, 2004 03:05 AM
