2point6's Skunk2 manifold second go...
Old Aug 14, 2004 | 04:49 PM
2point6's Avatar
Default 2point6's Skunk2 manifold second go...
Well, I ran up to Locash racing to use their dyno and Hondata tuning skills in an effort to see a gain with the Skunk2 manifold on my car. After quite a bit of tuning, I ALMOST broke even with the Skunk2 Vs. Euro R. THe Skunk2 manifold DID make about 3 more WHP in the extreme top end (7600 rpm), However Lost HP and TQ all around starting low around 2000 RPM up through 6000 rpm. At times the dyno plots were almost overlapping, but the skunk2 was down 1-2 whp and TQ and at times more. This IS a back to back manifold comparison HEAT ADJUSTED... meaning no cooling time. My engine was operating at 185 degrees+ for all of the recordings. IMO the Skunk manifold is COMPARABLE at best to the Euro R. Given that the Euro R must be modified... The Skunk2 manifold's deletion of the EGR and relocation of te IACV, comes down to these 4 trade offs... Fitment, Emissions leagal, Modifications to the manifolds and Minor drivability differences. The skunk is a nice looking part, but it will be coming off of my car to be replaced with my Euro R manifold until a new product comes out... I will be posting the dyno graphs as I am awaiting an Email from Locash.
NOTE: MY SET-UP IS UNCOMMON... this does not mean gains CAN'T be made with this manifold. If you are willing to sacrifice low and mid to gain up high, this could work for you... so smile, most likely you didn't waste your money.
Modified by 2point6 at 6:16 PM 8/14/2004
Old Aug 14, 2004 | 05:01 PM
PreIudeSI's Avatar
From: California ... Beauuutiful, so cal, pwnited States
Default Re: 2point6's Skunk2 manifold second go... (2point6)
yeah, i'd rather have constant 1-2 hp in the low-mid range than 3hp top end too. post those graphs
Old Aug 14, 2004 | 05:31 PM
Shakes's Avatar
space cadet
what is the cost difference and how hard is it to find the EURO R manifold?
Old Aug 14, 2004 | 05:40 PM
PreIudeSI's Avatar
Default Re: 2point6's Skunk2 manifold second go... (Shakes)
i don't know about the cost of the euro r one but i do know it's a pain in the *** to modify it so it'll fit. I think 2.6 wrote a write-up on it, it may be on collective-racing.net, dunno though
Old Aug 14, 2004 | 05:41 PM
v4lu3s's Avatar
RTFM
id like to see a stock stroke h22a with the skunk2 manifold ont eh dyno, i suspect that the higher piston speeds may be looking for a higher velocity intake charge than the skunk2can provide, but then again i could jsut be talking out my *** too...
Old Aug 14, 2004 | 05:42 PM
ItalynStylion's Avatar
Would you suggest getting the Skunk2 if i have a stock IM on my prelude?
You didnt get results over the EuroR but would i over stock?
Old Aug 14, 2004 | 05:47 PM
2point6's Avatar
Default Re: 2point6's Skunk2 manifold second go... (ItalynStylion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ItalynStylion &raquo;</TD></TR><TR><TD CLASS="quote">Would you suggest getting the Skunk2 if i have a stock IM on my prelude?
You didnt get results over the EuroR but would i over stock?</TD></TR></TABLE>I have no doubt you would see gains with the skunk2 over a stock manifold. Tuning will be a must! Wether or not the Skunk2 is better than the euro R well, that depends on what it does on a Stock or nearly stock engine. We will see.
se93's Avatar
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">id like to see a stock stroke h22a with the skunk2 manifold ont eh dyno, i suspect that the higher piston speeds may be looking for a higher velocity intake charge than the skunk2can provide, but then again i could jsut be talking out my *** too...</TD></TR></TABLE>
I would also like to see the same thing.
Old Aug 14, 2004 | 05:52 PM
2point6's Avatar
I said this in my other post, so maybe we BOTH are talking out of our asses...lol. I believe there is something to the piston speed affecting the velocity of the intake charge.
Old Aug 14, 2004 | 05:55 PM
Kal's Avatar
Kal
Default Re: (2point6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point6 &raquo;</TD></TR><TR><TD CLASS="quote"> The skunk is a nice looking part, but it will be coming off of my car to be replaced with my Euro R manifold until a new product comes out..
Modified by 2point6 at 6:16 PM 8/14/2004</TD></TR></TABLE>
ITB's?
Old Aug 14, 2004 | 05:56 PM
2point6's Avatar
Default Re: (Kal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kal &raquo;</TD></TR><TR><TD CLASS="quote">
ITB's? </TD></TR></TABLE>
Nope.
Old Aug 14, 2004 | 06:18 PM
matix's Avatar
Well its good to see you got more power out of it then that last dyno. I will be dynoing mine soon and i have a stock motor. It will be within 2 weeks. Broke U.P.S employee here. I will post the dyno as soon as im done. Hopefully someone else will have dynoed before that though.
Old Aug 14, 2004 | 06:29 PM
charliec's Avatar
Default Re: (matix)
just out of curiosity, to put the breaking-even in perspective, have you ever dynoed the euro-r vs stock with your car?
Old Aug 14, 2004 | 06:54 PM
Jason kiDD's Avatar
DYNO PLOTS SCOTT!!!
Anyways not to take away from your thread but I went today and I made 200.71 whp and 158 trq. I will post up the plot tomorrow.. *cheezin*
Old Aug 14, 2004 | 07:26 PM
Adam.'s Avatar
Default Re: 2point6's Skunk2 manifold second go... (Jason kiDD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jason kiDD &raquo;</TD></TR><TR><TD CLASS="quote">DYNO PLOTS SCOTT!!!
Anyways not to take away from your thread but I went today and I made 200.71 whp and 158 trq. I will post up the plot tomorrow.. *cheezin*</TD></TR></TABLE>
Nice, Pat McGroin went today for a baseline and made 110whp/122wtq. Nice numbers if you ask me.
CEL for VTEC pressure switch and the guy at Car-Tek told him to clean his VTEC Solenoid. I wasn't there, I'm just postng this b/c i think he might be too embarassed too.
Old Aug 14, 2004 | 08:11 PM
locash's Avatar
I sent the charts to Scott's buddy, he may not have passed them on yet..
Here is a simple euro-r vs skunk2 manifold comparison, keep in mind that the ambient air temp was a few degrees cooler when testing the skunk2, but the coolant temps were near identical (~190)..
Runfile_033 is the Euro-R manifold
Runfile_042 is the Skunk2 manifold
Keep in mind that this is NOT anywhere near a stock h22a, and I would love to see a comparison on a stock h22a with the stock IAB manifold vs. the skunk2, I bet there would be some interesting gains and losses..
Old Aug 14, 2004 | 09:32 PM
2point6's Avatar
Thankyou, Joe for all the help.
BTW, if anyone is in the Phoenix area, I highly recomend Locash for any tuning needs. Superb service and attention to detail. It does make a difference. BTW, my Skunk2 manifold is up for sale.
Old Aug 15, 2004 | 12:36 AM
Jason kiDD's Avatar
Here you go guys..
Old Aug 15, 2004 | 01:05 AM
Daboi630's Avatar
^ what's the diff in the two runs? just the manifold?
Old Aug 15, 2004 | 04:58 AM
se93's Avatar
Default Re: (Jason kiDD)
Jason:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jason kiDD &raquo;</TD></TR><TR><TD CLASS="quote">Here you go guys..
</TD></TR></TABLE>.
Looks interesting. What's your H22A setup?
Old Aug 15, 2004 | 05:25 AM
Behan's Avatar
Default Re: (se93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by se93 &raquo;</TD></TR><TR><TD CLASS="quote">
Looks interesting. What's your H22A setup? </TD></TR></TABLE>
very interested in seeing your mods and the differences between the 2 runs. When was the baseline run done, with what mods, etc.
Old Aug 15, 2004 | 07:30 AM
Rick Solis's Avatar
Was this an untuned baseline vs tuned with S2 IM?
Old Aug 15, 2004 | 08:01 AM
satan_srv's Avatar
Default Re: (Rick Solis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rick Solis &raquo;</TD></TR><TR><TD CLASS="quote">
yeah...what is this dyno?
Old Aug 15, 2004 | 08:08 AM
VSBB6's Avatar
Jason KiDD: Can you list your mods before and after the runs? Thanks!
Old Aug 15, 2004 | 08:28 AM
PirateMcFred's Avatar
Default Re: (VSBB6)
This is Jason kiDD's mods list from 2point6's first Skunk2 mani thread:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jason kiDD &raquo;</TD></TR><TR><TD CLASS="quote">Nah I didint jump on the manifold bandwagon just yet because I wanted to be sure it would actually help. Most people think that when they bolting on parts without actual facts that they are actually gaining power..
My setup..
98 JDM Type SIR w/LSD
93 Civic CX body
ACT Clutch & Plate
Clutchmasters Flywheel
ATR Crank Pulley
Aeromotive FPR
MSD Digital 6 w/ Blaster 2 Coil
Greddy Header
Age Engineering Chipped P28
VAFC
2.5 Exhaust, no cat, Dynomax 2.5 Turbo Muffler
Everything else is stock.. I will try to get as much graphs as possible. SAE corrected.
