**HELP** axle/tranny question
Old Aug 14, 2004 | 04:05 PM
limey156's Avatar
Default **HELP** axle/tranny question
i have a '94 civic hatch (DX), with a turbo'd b16 and gsr tranny swapped in. my tranny is grinding in 1/3/5th gear, and im looking at buying a used one. also, my passenger side cv joint is going bad, the boot is torn. my present tranny has an aftermarket clutch/flywheel installed. my questions-
A) what axle do i need to get? a b-series axle like the one below? or a D-series like my car came stock?
https://honda-tech.com/zero...49584
B) if i get a new tranny, can i switch over the clutch/flywheel i already have? i heard somewhere you can only install a clutch once, if re-installed it goes bad. and should i get the flywheel resurfaced if i switch it?
C) could i get an estimate of how long/difficult the job would be, i have acces to a lift/air tools, (but only for 8 hrs at a time) and a bit of experience doing general work on cars. i did a custom turbo install on my car.
thanks for any and all help
Old Aug 15, 2004 | 01:26 PM
limey156's Avatar
Default Re: **HELP** axle/tranny question (limey156)
nobody?
mofo951
Jun 10, 2008 08:24 PM
ApolloSpeed
Feb 12, 2006 01:07 PM
hybrid1990crx
Feb 18, 2005 06:01 PM
Emong3
Jun 16, 2004 01:19 AM
94si94cx
Sep 14, 2003 03:39 PM
