ITR manifold on b16 JDM SIRII vs b16 stock manifold
Old Aug 14, 2004 | 04:00 PM
racekar's Avatar
Default ITR manifold on b16 JDM SIRII vs b16 stock manifold
I have a JDM B16 SIRII motor with stock throttle body/manifold and also have a spare ITR manifold. If i swap the ITR manifold is it a direct swap i searched and some say its a direct swap and others say you need idle valve and gsr fuel rail for the swap is that true?
thanks
Old Aug 14, 2004 | 04:23 PM
racekar's Avatar
anyone with stock b16 fuel rail and ITR manifold or did you upgrade the fuel rail also?
Old Aug 14, 2004 | 06:29 PM
beaterdriver's Avatar
i believe its a direct swap, but its better, and bigger
Old Aug 14, 2004 | 09:09 PM
racekar's Avatar
well b16 is better than type R manifold on low/mid range and type R is better for mid/high range and better for built engines from the research.
I want to know if the stock b16 fuel rails are good enough for the type r manifold or if i will run into problems later on thanks
Old Aug 15, 2004 | 12:16 PM
smart monkey's Avatar
Default Re: (dchung1)
the R man is fine the rail and injectors will fit. you might not have to use those spacers however. as for the IACV I think the jdm one might not bolt on. you will need a 92-95 civic one or 94-LS. also I believe you need a different Throttle cable and bracket.
Sivic87
Apr 16, 2006 07:35 PM
92_EGhatch
Jan 8, 2005 06:59 PM
HamiltonRex
Oct 27, 2004 06:11 AM
garylythgoe
Sep 30, 2004 04:41 PM
