How do u remove the rear seats on a 4 door EK?
Old Aug 14, 2004 | 03:37 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
Default How do u remove the rear seats on a 4 door EK?
Did a search, didnt find any instruction for my application. Just need to know how to pop the bottom cushion off. I need to remove them so i can bolt down the straps for my new seatbelt harness. Thanks.
Old Aug 14, 2004 | 04:03 PM
perlmeister8's Avatar
Default Re: How do u remove the rear seats on a 4 door EK? (rukawa1one)
Just pull it up, be sure to feed the seatbelt clips through the cushion. Then you should be able to see where it connects to the body.
Old Aug 15, 2004 | 09:46 AM
rukawa1one's Avatar
Default Re: How do u remove the rear seats on a 4 door EK? (perlmeistere81)
so just pull it up and it should pop off? I think i tried doing that, but there are these metal tabs holding it down at certain points. Maybe i didnt pull pull hard enough? Thanks for the info.
Old Aug 15, 2004 | 10:46 AM
Pull the part of the cushion that is closest to the rear of the vehicle upwards and towards the front of the car.
Old Aug 15, 2004 | 10:17 PM
rukawa1one's Avatar
got it now thanks alot!
Old Aug 15, 2004 | 11:42 PM
LEVO's Avatar
In the back of the bottom coushion where the bottom and top coushion meet about 5 or 6 inshes to the right (facing the rear of the car) you will find a hidden 10 mm bolt. Take that out then the back should lift up and the front will pop out.
Old Aug 16, 2004 | 04:14 AM
civic-4-ges's Avatar
Default Re: How do u remove the rear seats on a 4 door EK? (LEVO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LEVO &raquo;</TD></TR><TR><TD CLASS="quote">In the back of the bottom coushion where the bottom and top coushion meet about 5 or 6 inshes to the right (facing the rear of the car) you will find a hidden 10 mm bolt. Take that out then the back should lift up and the front will pop out.</TD></TR></TABLE>
Found this after doing some searching recent;y myself. Kinda hiddne, have to know where to look. About 1/3rd the way from the end on the drivers side.
Flava
May 30, 2006 09:48 AM
-anakist-
Oct 27, 2004 07:56 AM
AZSupraT
10
Jul 22, 2004 01:02 PM
JL 74
Mar 25, 2002 08:30 PM
Chip398193
Jan 16, 2002 08:59 AM
