Autotensioner Bolt
Old Aug 14, 2004 | 11:26 AM
metalgears's Avatar
Default Autotensioner Bolt
What is an easy way to break loose the autotensioner bolt?
I am tried using an 6" open and box end 10mm wrench but I cant it too budge.
Old Aug 14, 2004 | 11:31 AM
PreludeRacer023's Avatar
Default Re: Autotensioner Bolt (metalgears)
socket...with a short breaker bar, also its easiest to reach it from below with the car on a lift or on jackstands
Old Aug 14, 2004 | 11:36 AM
Hawkze_2.3's Avatar
Default Re: Autotensioner Bolt (PreludeRacer023)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PreludeRacer023 &raquo;</TD></TR><TR><TD CLASS="quote">socket...with a short breaker bar, also its easiest to reach it from below with the car on a lift or on jackstands</TD></TR></TABLE>
Also you can remove the driver side motor mount and jack the engine up/down a little to get more clearance.
Old Aug 14, 2004 | 12:34 PM
metalgears's Avatar
I dont know what socket you guys are using but i am almost positive mine wont fit.
There isnt enough room to clear the nut and fit the socket over it.
This is from the top and the bottom.
Old Aug 14, 2004 | 12:53 PM
Hawkze_2.3's Avatar
I've also used a 12 point wrench and hit it with a mallet to break the bolt loose...
HCJDM1
33
Feb 5, 2007 05:50 PM
Outkast95LS
Jan 4, 2006 08:32 AM
type Gendy
22
Apr 1, 2004 11:29 AM
Liquidgsr
Mar 25, 2004 01:32 PM
.RJ
22
Mar 12, 2004 03:23 PM
