SPC Adjustable Ball Joint Kit for 1988 Honda CRX Front Suspension
Hi, I just bought some SPC Adjustable Ball Joint kits for my 1988 Honda CRX. I've been researching about the upper control arms sourced from 1990-1991 Honda Civic CRX must be used? Why can't I use my 1988 Honda CRX arms? Also, will I be able to use the 1990-1991 Honda Civic (not CRX) Upper Control Arms to do this swap?
Please reply if you can help. PM's are greatly appreciated.
-Jon
-Jon
i want someone to make complete adjustable upper control arms..not just some ball joint swap..but whatever works for now
Yeah as well do i. However, is there anyways I can just take out the balljoint (cut the weld and put the new balljoint in?). Reply if ya got an answer pls
you need a 90-91 crx OR civic UCA. i have the kit on my 90 civic. you wouldnt want to weld it in, it lines up perfectly w/ the 90-91 arm. just get one from a junkyard.
lrcrx90
Jan 5, 2007 02:02 PM
bmg123
Oct 1, 2004 11:07 PM
