R swap into a 91 civic si?????help
My buddy asked me to ask about the parts needed for this swap
If anyone has done this before please reply with what is needed
or any problems
or any problems
you will need the following parts:
B series MMK
cable to hydro conversion(if true type r)
Hasport vtec harness
pre obd b series dizzy
pre obd b series injectors or change clips( may have different impedance)
b series cable VSS( type r is elec. I believe)
maybe more but that is a start
B series MMK
Why go to all the trouble of doing a hydro conversion but not an OBD-I conversion?
Use the Type R distributor
pick up an OBD-I P28 and have it chipped
pick up an obd-o to obd-I conversion harness
type r is obd II not obd I so p28 might not work you would then have to get obd I dizzy, injectors ect for obd I when a type R is obd II.
My car is a gsr, but yu should get the idea of whats needed. You should go obd1 (if smog is not a issue, CA it is). Check my sig. for details.
groundedcivic91
Jan 19, 2005 09:33 PM
PY01ITR42
Jul 12, 2002 10:37 PM
