h23 + pauter rods = notching?
Old Aug 14, 2004 | 08:31 AM
fastludeh22's Avatar
Default h23 + pauter rods = notching?
i got my pauters yesterday and there was a paper in the box that said notching the bottom of the cylinder walls may be ness. anyone have to do this?
Old Aug 14, 2004 | 06:07 PM
PirateMcFred's Avatar
Default Re: h23 + pauter rods = notching? (fastludeh22)
Have you got the block out and apart? it would not take long to do a test fitment. Sorry I can't help but here is a bump
Pirate
Old Aug 16, 2004 | 07:50 PM
Default Re: h23 + pauter rods = notching? (PirateMcFred)
well i just got the block last night. i would have had it apart, but i broke a socket last night...then i worked 15 hr's today. we'll see after work tomorrow
Old Aug 17, 2004 | 06:52 AM
15 hours huh? That sucks. Pull some vacation to do some work that you do want to do. haha. Anyway hope it works out for you.
Pirate
Old Aug 17, 2004 | 09:55 AM
LudeyKrus's Avatar
I gotta give ya a call sometime, Vinny! I'm pretty sure I still got your number! If I could just keep my car from being constantly busted.....
Old Aug 17, 2004 | 01:34 PM
prelittlelude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastludeh22 &raquo;</TD></TR><TR><TD CLASS="quote">i got my pauters yesterday and there was a paper in the box that said notching the bottom of the cylinder walls may be ness. anyone have to do this?
i have also heard about this, its just because the huge stroke of the h23 and the pauter rods are just so much bigger, i personally have not ever done an install that had to be notched, but im thinging you will have to
Old Aug 17, 2004 | 05:12 PM
h22 civic's Avatar
Default Re: h23 + pauter rods = notching? (prelittlelude)
i had to notch my h22 pauters talk to earl
Old Aug 17, 2004 | 05:23 PM
The F23 block looks as stout as the H and is already notched for its 97mm stroke. Just to let you know.
Pirate
Old Aug 17, 2004 | 06:49 PM
Default Re: h23 + pauter rods = notching? (h22 civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22 civic &raquo;</TD></TR><TR><TD CLASS="quote">i had to notch my h22 pauters talk to earl </TD></TR></TABLE>
i got them from earl he said he didnt think so, but hadn't done an h23 yet. he also said clearence should be a little better when sleeved with him, then stock.
i got the head off today. block looks ok, valves ae screwed...but i knew that. well see if they hit tomorrow.
Old Aug 24, 2004 | 08:07 AM
i got the head off today. block looks ok, valves ae screwed...but i knew that. well see if they hit tomorrow.</TD></TR></TABLE>
is this a fucked h23 you bought or just another one of your motors.
Old Aug 24, 2004 | 08:27 AM
spoolinlude's Avatar
I live under a rock
My pauters fit my H23 no problem......
Old Aug 24, 2004 | 10:35 AM
Prelude91siT's Avatar
i know people with b20a's had to notch there cylinder walls when using those rods. side not the 3rd gen b20a and the h23 use the same rods.
Old Aug 24, 2004 | 03:33 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelittlelude &raquo;</TD></TR><TR><TD CLASS="quote">
is this a fucked h23 you bought or just another one of your motors.</TD></TR></TABLE>
a fucked one i bought off 95lude. that thing must have had 200k+ on it. it was all black and brown sludge inside.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolinlude &raquo;</TD></TR><TR><TD CLASS="quote">My pauters fit my H23 no problem......</TD></TR></TABLE>
good cause i forgot i dont have any 87 mm pistons to test with.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prelude91siT &raquo;</TD></TR><TR><TD CLASS="quote"> side not the 3rd gen b20a and the h23 use the same rods.</TD></TR></TABLE>
kind of crazy. as in same size? cant be same part #. maybe a good upgrade for b20 owners?
i should be boxing up and shipping out my h23 to be sleved tonight, all looked good in the bottom end...if i can get my lazy *** up.
Old Aug 25, 2004 | 06:15 AM
same everything. thats what we use for the most part is h23 rods cause only like one person actually makes rods for r engines. if u ask me they r the same engine pretty much just a bigger bore. i think thats y the h23 uses bseries cam gears cause its pretty much a bored out b20a. we use the same lenth rods so that pretty much tell is all. goodluck on ur project
BrockNB
May 26, 2007 09:24 AM
ludesleep
Jul 13, 2005 05:44 AM
fastludeh22
Feb 4, 2005 07:40 PM
prelude beast
Aug 8, 2003 08:49 AM
Greyout
May 7, 2003 07:30 PM
