D16a6 to ZC
Old Aug 14, 2004 | 02:00 AM
LorenGeist's Avatar
Default D16a6 to ZC
new to the scene and am looking for a motor swap for my 89 crx si. From my understanding if you have a 88-91 ZC it will be OBD-0. and the d16a6 is OBD-0. so the only thing i should need other than the ZC is the correct ECU and its a dirrect bolt in correct?
Old Aug 14, 2004 | 10:36 AM
d16X's Avatar
yea im pretty sure that it is a direct bolt up
Old Aug 14, 2004 | 10:50 AM
ServiceAdvisor's Avatar
Both the SOHCZC and DOHCZC are basically bolt-ons. They both use the stock mount locations, and since you have an Si you can keep your stock ecu. But its recommended to upgrade to an 88-89 integra Ecu for a more aggressive fuel map. Both DOHCZC and SOHCZC motors can have your stock A/C system attatched. - Darrell
Old Aug 14, 2004 | 06:05 PM
jlicrx's Avatar
Default Re: D16a6 to ZC (LorenGeist)
you will have some wiring to do at the distributor
Old Aug 14, 2004 | 10:30 PM
hatchinprogress's Avatar
Default Re: D16a6 to ZC (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">you will have some wiring to do at the distributor </TD></TR></TABLE> isn't it like two wires?
Old Aug 14, 2004 | 10:33 PM
LorenGeist's Avatar
Default Re: D16a6 to ZC (hatchinprogress)
what two wires would it be?
Old Aug 14, 2004 | 10:36 PM
HondaKPX's Avatar
se it works fine. i have my D16 on the floor in my garage right now even. ZC is almost ready to go in. tomarow is swap day.
sit220's Avatar
http://www.dmoore.com/crx/zc-phase3.htm
Old Aug 15, 2004 | 01:07 AM
LorenGeist's Avatar
Default Re: D16a6 to ZC (sit220)
ok so the si headers dont match up exactly? where do i get the header gaskets and header? what about the air intake to any companies make them for the DOHC ZC or are they interchangable with another model?
Old Aug 15, 2004 | 01:51 AM
LorenGeist's Avatar
bump
Old Aug 15, 2004 | 02:57 AM
NCRXSi's Avatar
The site sit220 listed will answer most of your questions. The one thing that isn't covered there that I ran into with the swap was the flywheel. If you are going to use an Si clutch kit, you'll have to use your Si flywheel. The ZC flywheel is the same diameter however the mounting points for the clutch pressure plate are about an inch smaller in diameter on the ZC flywheel. If you use the ZC flywheel I have read some where that you will have to use the 89 Civic DX clutch kit. I haven't tried that so I don't know positively, but I can attest to the Si flywheel and clutch kit fitting.
The other questions you had on the distributor wiring and header are on the dmoore site. The wiring is simply, you just remove 2 of the wires and extend them to the cam angle sensor. Here's the link for the <u>wiring diagram</u>
Old Aug 15, 2004 | 03:38 AM
LorenGeist's Avatar
Default Re: D16a6 to ZC (NCRXSi)
whats the "sit220" website that your talking about thanks for your help
Old Aug 15, 2004 | 03:41 AM
NCRXSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sit220 &raquo;</TD></TR><TR><TD CLASS="quote">http://www.dmoore.com/crx/zc-phase3.htm</TD></TR></TABLE>
Old Aug 15, 2004 | 03:44 AM
xjun10rx's Avatar
real easy swap... just finished it my self... first ever swap ive done and it went like nothing..
everything bolts right in and all u have to do is connect those two wire and ur done ...
well if u come across anything just hit me up.. email me if u want xjun10rx@aol.com good luck
Old Aug 15, 2004 | 03:45 AM
LorenGeist's Avatar
alright thank you! One last question if anyone can help me out. If i wanted to run a lightweight flywheel for the street say anywhere from 10 to 12 pound would a non high performance clutch with a street disc be ok? or do i have to run something along the lines of a centerforce dual friction or A.C.T.?
Old Aug 15, 2004 | 09:23 PM
LorenGeist's Avatar
Hey Luke... I think you should register for your own account lol . Bump.
Old Aug 15, 2004 | 09:48 PM
The ZC's Avatar
Run an exedy.
I got a stage 1 and its fine.
89crxsiVT
Apr 25, 2007 05:52 PM
gator88
Aug 25, 2006 12:46 PM
funkyfreshpnoy
Mar 12, 2006 05:12 AM
dangvernhead
Oct 24, 2004 08:53 PM
itsmebeaner1987
Oct 8, 2004 03:40 PM
