just making sure, are 97 cl f22b1 and 96 accord f22b1 interchangeable?
Old Aug 13, 2004 | 11:02 PM
vladd's Avatar
Default just making sure, are 97 cl f22b1 and 96 accord f22b1 interchangeable?
as you can probably tell, i don't know anything about accords. my friend's timing belt snapped in his 97 4-cyl cl, and i have a spare engine out of a 96 accord ex lying around. they're completely interchangeable, right? wiring, mounts, etc are the exact same? just making sure before we swap it.
Old Aug 14, 2004 | 09:01 AM
f22b-dohc's Avatar
screw it h22 it
Old Aug 14, 2004 | 11:15 AM
twkdCD595's Avatar
Default Re: (f22b-dohc)
wel if you have a free engine sitting... I would definately use it before buying another...
anyways... yes I do believe that they are interchangeable.
Old Aug 15, 2004 | 09:01 PM
vladd's Avatar
Default Re: (twkdCD595)
anyone know for sure? and yes, there's a reason why we're putting in another stock engine instead of a h22; $$. plus my friend wants to get rid of the car, so no point of modifying it.
Old Aug 16, 2004 | 04:30 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: (civicdxtyper)
I would say yes. They are both F22B1 and OBD2 so all the wiring should be exactly the same. Mounting is going to be the same. You should be just fine, go for it.
Old Aug 16, 2004 | 12:56 PM
AVcTcEoCrd's Avatar
Default Re: (TouringAccord)
YES IT IS FOR FACT THE SAME, EVERYTHING SHOULD BE THE SAME.
theSHK
Apr 24, 2013 06:50 PM
gabR.
Mar 11, 2010 03:59 PM
bozos_si
May 22, 2006 08:30 AM
MtbikingKing
Apr 26, 2006 07:42 PM
