how to identify axles???
i purchased some axles that are suppose to be integra type-r ones. but i do not know whether they are usdm or jdm. how would you tell what type of axles you have.. where would you measure to tell whether they are jdm or usdm. is there a way you can count the amount of spindles to tell?
jdm/usdm doesnt matter unless you wanted the 98spec jdm itr setup. Which are 36mm axle nut splines. Other than that they are all the same for the hydro b setups.
oem
Jan 27, 2003 08:54 PM
