I need verification about something
I've been talking to a guy with a really nice '91 Si with a B16A swap. He told me the car has a vibration problem at all speeds, and claims all EF's with swaps have this problem... Is this true or should I stay away?
He's running HAsport mounts and "88-91" Integra axles. I've been searching the archives and people have commented about this, but would like some fresh opinions on the matter. TIA
My friend has a 91 si too with a b18c5 swapped into his car using haasport motor mounts tooo, and his car shakes a whole lot all the time... Im not sure if this goes for all swaps, or maybe its just the mounts... But my opinion is that its just the mounts... hope that helps !!!
i believe the mounts is what would cause the shakin not the swap i had a rex with a zc and rubber mounts (there was shakin) i have a hatch with a zc and stock mounts(no shakin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kid-honda »</TD></TR><TR><TD CLASS="quote">With solid mounts you have got to expect it, I would drive if first to make sure its "mount vibrations" and not something else.</TD></TR></TABLE>
my Hasport mounts almost shake my fillings in my teeth out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by APEX CRX »</TD></TR><TR><TD CLASS="quote">
my Hasport mounts almost shake my fillings in my teeth out.</TD></TR></TABLE>
Same with mine. I think mine would shake less if I didn't have such an idle problem. I'm glad someone finally confirmed that my car is not messed up.
my Hasport mounts almost shake my fillings in my teeth out.</TD></TR></TABLE>Same with mine. I think mine would shake less if I didn't have such an idle problem. I'm glad someone finally confirmed that my car is not messed up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by michaelOlson »</TD></TR><TR><TD CLASS="quote">Same with mine. I think mine would shake less if I didn't have such an idle problem. I'm glad someone finally confirmed that my car is not messed up.</TD></TR></TABLE>
Ya, right when I did my 2nd b series swap my tps was off a lil, causing the idle to fluctuate, it shook like crazy untill I caliberated it.
My mounts only shake when its cold outside.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kid-honda »</TD></TR><TR><TD CLASS="quote">With solid mounts you have got to expect it, I would drive if first to make sure its "mount vibrations" and not something else.</TD></TR></TABLE> i use hasport too
it vibrates a bit but you'll get use to it though
Thanks everybody, now I know I'm not trying to buy a defective vehicle, at least in that respect.
Is there any way to counter this problem?
i have hasport mounts and it doesnt shake tat much. check all ur interior bolts and screw.
does not shake at idle only when accelerating at a complete stop
90civicstdgold
Oct 28, 2010 01:58 AM
Joeski99Si
Nov 19, 2008 07:49 AM
JapJunkie
Aug 27, 2004 04:49 PM
Jurassic Four
Jun 27, 2004 10:04 AM
