Wheels, Tires, Brakes, and Suspension Wheel, Tire, Brake and Suspension Parts (Wheels, Tires, Coilovers, Lug Nuts, Camber Kits, Rim/Tire Tools)
Eibach Camber Alignment Kits
Old Aug 13, 2004 | 02:04 PM
prostreetonline's Avatar
Default Eibach Camber Alignment Kits
After the installation of either an Eibach Pro-Kit or Sportline spring set, a vehicle's alignment should always be checked. Once lowered, a wheel's camber may become increasingly negative, meaning the top of the tire is angled inward (toward the center of the vehicle). While some negative camber aids in improving traction and road adhesion, too much can result in peculiar handling and accelerated tire wear.
Eibach offers a complete range of alignment kits which offer a simple, affordable solution to adjust negative camber. These alignment kits not only assist in adjusting a vehicle's camber back to factory specifications but they also allow the experienced chassis tuner to utilize the increased adjustment range to dial-in a performance alignment that uses negative camber to maximize a chassis' potential. Turn-in becomes more precise and handling increasingly crisp and predictable. High-speed stability is also enhanced making an alignment kit from Eibach almost a necessity for the serious performance tuner.
Acura Integra 1990 - 1993 5.84945K $194.62 Trim: 2 and 4-Door (Incl. GS-R) specs: Front -0/+1.5
Acura Integra 1990 - 1993 5.84580K $90.00 Trim: 2 and 4-Door (Incl. GS-R) Specs: Rear +/- 0.75
Acura Integra 1994 - 2001 5.84945K $194.62 Trim: 2 and 4-Door (Incl. GS, GS-R, RS, LS and Type-R) Specs: Front -0/+1.5
Acura Integra 1994 - 2001 5.84580K $90.00 Trim: 2 and 4-Door (Incl. GS, GS-R, RS, LS and Type-R) Specs: Rear +/- 0.75
Acura Legend 1991 - 1995 5.84945K $194.62 Trim: 2 and 4-Door Specs: Front -0/+1.5
Acura RSX 2002 - 2003 5.81260K $43.20 Trim: Incl. Type S Specs: Front +/- 1.75
Acura RSX 2002 - 2003 5.67230K $238.50
Honda Accord 1986 - 1989 5.84600K $88.88 Trim: 2 and 4-Door Specs: Front +/-.75-1.50 (Left)
Honda Accord 1986 - 1989 5.84650K $88.88 Trim: 2 and 4-Door Specs: Front +/-.75-1.50 (Right)
Honda Accord 1986 - 1989 5.84680K $108.00 Trim: 2 and 4-Door Specs: Rear +/- 0.75
Honda Accord 1990 - 1997 5.84945K $194.62 Trim: 2 and 4-Door, 4 Cyl. (Incl. Wagon) Specs: Front -0/+1.5
Honda Accord 1990 - 1997 5.84680K $108.00 Trim: 2 and 4-Door, 4 Cyl. (Incl. Wagon) Specs: Rear +/- 0.75
Honda Accord 1995 - 1997 5.84945K $194.62 Trim: 2 and 4-Door, 6 Cyl. (Exc. Wagon) Specs: Front -0/+1.5
Honda Accord 1995 - 1997 5.84680K $108.00 Trim: 2 and 4-Door, 6 Cyl. (Exc. Wagon) Specs: Rear +/- 0.75
Honda Accord 1998 - 2002 5.67090K $244.12 Trim: 2 and 4-Door, 4 Cyl. (Incl. EX, DX, and LX) Specs: Rear -2.0/+4.00
Honda Accord 1998 - 2002 5.67090K $244.12 Trim: 2 and 4-Door, 6 Cyl. (Incl. EX, DX, and LX) Specs: Rear -2.0/+4.00
Honda Civic 1988 - 1991 5.84945K $194.62 Trim: Exc. Wagon Specs: Front -0/+1.5
Honda Civic 1992 - 1995 5.84945K $194.62 Trim: 2 and 4-Door Specs: Front -0/+1.5
Honda Civic 1992 - 1995 5.84680K $108.00 Trim: 2 and 4-Door Specs: Rear +/- 0.75
Honda Civic 1996 - 2000 6.13100K $367.88 Trim: 2 and 4-Door (Incl. EX, DX, HX, LX and Hatchback M Specs: Front +1.0/-3.00
Honda Civic 1996 - 2000 5.84580K $90.00 Trim: 2 and 4-Door (Incl. EX, DX, HX, LX and Hatchback M Specs: Rear +/- 0.75
Honda Civic 1999 - 2000 6.13100K $367.88 Trim: Civic Si Specs: Front +1.0/-3.00
Honda Civic 1999 - 2000 5.84580K $90.00 Trim: Civic Si Specs: Rear +/- 0.75
Honda Civic 2001 - 2004 5.81260K $43.20 Trim: 2 and 4-Door (Incl. EX, DX, HX, and LX Models) Specs: Front +/- 1.75
Honda Civic 2001 - 2004 5.84580K $90.00 Trim: 2 and 4-Door (Incl. EX, DX, HX, and LX Models) Specs: Rear +/- 0.75
Honda Civic 2003 - 2004 5.81260K $43.20 Trim: Civic Si Specs: Front +/- 1.75
Honda CRV 1997 - 2001 6.13100K $367.88 Trim: Incl. EX and LX Specs: Front +1.0/-3.00
Honda CRX 1988 - 1991 5.84680K $108.00 Trim: Exc. Wagon Specs: Rear +/- 0.75
Honda Del Sol 1993 - 1997 5.84945K $194.62 Specs: Front -0/+1.5
Honda Del Sol 1993 - 1997 5.84580K $90.00 Specs: Rear +/- 0.75
Honda Prelude 1992 - 1996 5.84945K $194.62 Trim: Incl. All Wheel Steering Option Specs: Front -0/+1.5
Honda Prelude 1992 - 1996 5.84945K $194.62 Trim: Incl. All Wheel Steering Option Specs: Rear -0/+1.5
Honda Prelude 1997 - 2002 5.84945K $194.62 Trim: Incl. SH Option Specs: Rear -0/+1.5
For more applications or to order, click here:
FREE SHIPPING
TegGsr4dr
Jul 10, 2007 09:35 AM
JdmB16Eg6
Suspension & Brakes
Mar 28, 2006 10:29 AM
Caffeine Slug
Sep 28, 2001 09:56 PM
ALF
Aug 16, 2001 05:47 PM
