Squeaky Brakes
i think my rotor is warp but not sure...my brakes squeak everytime i press on the brakes...could it be anything other than the rotors? its a 1990 honda accord btw.
if your breaks get low then there is pices of metal that will start to hit the rotor and squeek ( the ware indicator)..if your rotors were warped then you would feel a vibration in the steering whenever you hit the brakes...autozone (or any autoparts store) should have some type of spray for that ..i beleive is called **brake quieter** they say the squeeking cause by micropores in the pads and spraying then on the pads will work. we use dit on a 97 audi A4 and it did the trick( take of the tire 1st and remove the pad from the caliper)
Trellis
Mar 12, 2003 04:50 PM
