ls vtec head studs
Old Nov 30, 2001 | 09:47 PM
g4b17's Avatar
New User
Default ls vtec head studs
i have a b18b short block out of a 90 integra and a complete 92 b17a1. the bottom end in the b17 is dead (too much bottle) so it is time to build a new engine. i was thinking of using the b17 head with the b18b block. i have heard of people having problems with head studs lining up as well as cooling holes. another problem i have heard about is clearance in the cylinders. does anyone know of these problems with this set up? has anyone tried this set up? any help you can give me is great.
Old Nov 30, 2001 | 09:55 PM
rainforest's Avatar
Default Re: ls vtec head studs (g4b17)
just get gsr head studs. and the dowle pins have to be drilled because they are smaller on ls's. and i never heard of any problems with cylinder clearance????sorry and remount the dowles on the other side.
[Modified by rainforest, 7:20 AM 12/1/2001]
Old Nov 30, 2001 | 10:38 PM
g4b17's Avatar
New User
Default Re: ls vtec head studs (rainforest)
cool thanks, what i mean by cylinder clearance is between the valves and pistons.
Old Dec 1, 2001 | 01:41 PM
lsvtec42's Avatar
New User
i used a stock ls block and b16 head with advanced intake cam...I did expierence the smallest hint of valves tapping...be careful if your not gonna change the pistons and do not use adj. cam gears if you use a stock bottom end.
good luck
Old Dec 1, 2001 | 07:07 PM
martini's Avatar
The valve relief cups on the LS pistons aren't big enough for the B16A valves. It's especially a problem with resurfaced head, or thin headgasket.
boosted98acura
May 13, 2008 07:59 AM
shoebox
Dec 15, 2006 05:38 AM
Dark_Teg
Jun 1, 2006 02:18 PM
Acura_I-RS
Sep 10, 2005 01:53 AM
The Stance
41
Jul 20, 2005 11:13 AM
