ECU Code 6
6 ECT - water temperature sensor
Is this on the thermostat housing on the back side of the engine, or is it just underneath the distributor?
This is the last code that I am throwing I have fixed the rest... now it is still sitting "Limp Mode" and wont go past 3200RPM
Thanks.
Thanks.
Needs to be About 20% Cooler
The water Temp, (TW) and the temp. gague sender is under the dizzy.
There are two plugs that go from engine to main and vice versa harneses. there the big 10+ plugs on the shock towers.
Import_spoon
Oct 25, 2007 07:09 AM
