Which Cam gears for a ZC?
well, i HAD a set of hayame b16 cam gears but they set my timing back by a full tooth... made me fail emisisons and bogged the **** out of my car. with stock cam gears i'm doing way better, but then again i'm jus waiting for my HKS ZC cam gears to come in from japan.
...the only thing w/ the b series gears is that they stick out from under the belt a bit....if that really bothers you, you can take em to a machine shop and get a bit milled off the back.
hmm i never got mine milled and they don't stick out. on the motor side of the gear it sits flush with the belt., also never had any problems with them rubbing on the timing belt cover. they fit fone under there.
Thanks for the info guys. So basically just get any of the B-series cam gears and slap them on. Or also use the ones that 91efzc has.
Anyhow thanks.
Anyhow thanks.
90civichbsi
Aug 27, 2003 07:58 PM
BigDaddyRich
Aug 18, 2002 08:14 PM
